Download (effectively) stops during Upload…
Fixes: 579
Re: Download (effectively) stops during Upload…
Will moving to Fibre (not Full Fibre) solve my problem?
It won't solve it as such!. According to the estimates you would have an upstream bandwidth of between 6 & 8 Mb which is 6 to 8 times your current 1 Mb. So you would need to upload at a higher rate to saturate it, but I suspect (if unrestricted) Youtube would still use all the available bandwidth. What you would be able to do though, is to have a higher limit for Youtube whilst still leaving a reasonable bandwidth left for acknowledging downloads.
