Download (effectively) stops during Upload…
CaseSensitive
Hi.
I have recently started publishing to YouTube.
Upload is slow (I kinda expected that) but when I upload, download grinds almost to a halt.
Viewing web pages, YouTube, Amazon Music is verrry slow until I stop Uploading.
Even the Internet connection symbol on the TV (ethernet direct to PlusNet router) shows ‘No Internet’.
Why?
30 REPLIES 30
Fixes: 384
Re: Download (effectively) stops during Upload…
What product (ADSL/FTTC) are you on, and what  are your 'normal' speeds?
CaseSensitive
Hi.
Not fibre. ‘Bog standard, ‘living in rural mid-wales, broadband. Don’t know what normal speed is. Can stream movies ok though.
Many years ago I used to publish to YouTube and I don’t remember Uploading stopping Downloading… Also years in Computer Support tells me this shouldn’t happen (?).
Visibility of your current sync speeds would be helpful, also which Hub are you using?
I suggest looking at https://www.waveform.com/tools/bufferbloat
HTH
Fixes: 384
OK - What router do you have, and what is the result of https://speedtest.btwholesale.com/ , please? - preferably as a screenshot.
RobPN
Fixes: 15
@CaseSensitive
It seems you're saturating your upload bandwidth thereby blocking ACK packets being sent, which in turn requires your download packets to need retransmission.
You need to limit your YouTube upload speed to below the maximum available to reserve some upload bandwidth for those ACK packets.
Edit: typo
CaseSensitive
PlusNet Hub Two. Firmware - v0.10.00.04201-PN
Fixes: 384
And the speed test?
CaseSensitive
Fixes: 384
Thanks. You are obviously on ADSL with those speeds, but on a fairly short line. I suspect, but don't know for 100% certainty, that the comments of others referring to saturation are correct.
I will leave it to others to suggest options.
CaseSensitive
Do you need to know equipment?
MacBook Air connected directly by ethernet to PlusNet Hub.
TV connected directly by ethernet to PlusNet Hub.
10/100 Switch connected directly by ethernet to PlusNet Hub.
Sky Q, Apple TV, Philips Lighting? Hub connected to 10/100 Switch.
4 iPhone/iPad using WiFi.
CaseSensitive
Thanks. Never heard of ‘saturation’. Hope there is a solution 🤞
Fixes: 384
As  I said, I'll leave it to those with greater knowledge/experience than me, but that amount of tech will probably also be slowing things down - you can only use the bandwidth once.
@CaseSensitive
Are you aware which product you are on; Unlimited Broadband (ADSL) or Unlimited Fibre (VDSL/FTTC). Do you know your contracted speeds?
If you not sure about the product the Hub's Status page will tell you, look at Connection type: Fibre Broadband (VDSL) or something else?
Can you also post Advanced Settings > Technical log >Information, this will detail your connection status. Make sure you obscure your broadband user name
Fixes: 580
@CaseSensitive  I'm afraid its simple. as @RobPN said you are saturating the upstream bandwidth with uploading to Youtube.
When you download information, the TCP/IP protocol needs to acknowledge the receipt of the data correctly by sending an ACK packet. When you are also uploading large (compared to your upstream bandwidth) amounts , these ACK packets must fight for transmission time with the uploaded data. If the router doesnt have any QoS prioritorisation for these ACK packets (and most ISP provided routers dont!) then they will get delayed. This, as @RobPN says causes downloaded data to be re-transmitted.
In the absence of any QoS settings you need to stop Youtube saturating the upstream by limiting it to less than your upstream speed
