Download Speed
- Re: Download Speed
Re: Download Speed
14-03-2009 7:49 PM
I have tried leaving the username and password blank I get error message username is missing?
Re: Download Speed
14-03-2009 7:56 PM
does the thompson version have this special login option?.
if not i would think looking on your router setup pages to create a username and password would allow dmt to login o.k
also is the ip address dmt is set to use the same as the one you use to login into your router 192.168.1.254
Re: Download Speed
14-03-2009 7:58 PM
Regarding the new stats - did you change the filter or disconnect the router. I am trying to find if it resynched all by itself
Re: Download Speed
14-03-2009 8:13 PM
DMT no special login option have tried admin admin no joy?
Re: Download Speed
14-03-2009 8:33 PM
Alternatively - if you didn't set one up and that doesn't work try username Administrator pasword blank (i.e. there isn't one)
Quote from: Jameseh Gleneagles - When you first set up your router, it probably asked you to choose a username and password. You will need to enter those details in order to access your routers configuration panel.
Otherwise, if you do a factory reset on your router, it will be:
username: admin
password: admin
You'll need to reconfigure the router though.
Note that the username and passwords are case sensitive
Re: Download Speed
14-03-2009 8:40 PM
Quote from: topham1 Regarding new stats yes I changed filter as suggested.
Ok Set myself up with a user name and password for my router now i get error message firmware version 7.4.4.7.0 is not supported?
How can i insert my screen prints doesn't like to paste even from paint?
Re: Download Speed
14-03-2009 8:46 PM
Re: Download Speed
14-03-2009 8:55 PM
Re: Download Speed
14-03-2009 8:56 PM
Re: Download Speed
14-03-2009 9:02 PM
Have you tried the quiet line test.
If you don't hear any noise then the only thing to do is start the fault reporting system http://faults.plus.net/
As part of this the test includes monitoring the error rate so it may pick up something. We can only try.
Re: Download Speed
15-03-2009 1:41 PM
Attached are my results from http://www.vwlowen.co.uk/internet/files.htm not sure what these mean, however I will raise a fault fingers crossed. Many Thanks for all your help.
Cece
Re: Download Speed
15-03-2009 4:49 PM
This wouldn't show up on a fixed speed line as it would always reconnect at 2000kbps approx.
If you want to make the monitoring easier you can change the frequency and the number of points. See this picture from the full version of routerstats - i would imagine the lite version is similar
The first picture shows the configuration button and the second the graph button with the bit you change
Is there anything happening in your house at those times - the phone ringing for example
Re: Download Speed
15-03-2009 5:44 PM
capture the graphs to folder and you will be able to see if the ferquency of the noise spikes are in line with somthing turning on ie central heating switching on/off.
edit: looking at you last post seems you got the graph capture sorted all ready
Re: Download Speed
15-03-2009 11:52 PM
Quote from: Oldjim If we can't get DMT to work try RouterStats http://www.vwlowen.co.uk/internet/files.htm
before connecting DMT open the mic options and tick the box marked ' allow untested firmware' save config and then connect.
Re: Download Speed
16-03-2009 1:27 AM
nice one for the info hope it works for the OP
