Dns seems high
- Re: Dns seems high
Re: Dns seems high
15-09-2013 5:55 PM
Re: Dns seems high
16-09-2013 8:54 AM
Re: Dns seems high
16-09-2013 10:01 AM
Re: Dns seems high
16-09-2013 3:20 PM
Quote from: nanotm as a real world test it got to the point that pages on PlusNet forums were taking up to 5 mins to load or in fact failing to load last night
Probably caused by something else. There was a separate problem affecting access to the Community Site yesterday (ref: 76907).
Re: Dns seems high
17-09-2013 7:46 AM
Re: Dns seems high
17-09-2013 3:58 PM
We've just upgraded one of the PCL servers and the situation looks much improved:
We'll be doing the rest of the PCL servers before moving onto the ones at Telehouse.
It'll take some time so shout up if things go awry again.
Re: Dns seems high
17-09-2013 8:05 PM
With peaks to around 300% slower.
So what's caused the higher load? Just a big traffic increase since people came back to work/school/university and stopped spending evenings outdoors?
Because the operating system revision can't have aged - the servers were like that before... And they were really fast not so long ago.
Re: Dns seems high
17-09-2013 9:24 PM
Just dropping you a reference point i'm on gateway ptw-ag04.
Nameserver Response Time (ms)
min/avg/max/stdev/retries
Local 0.61/0.62/0.62/0.00/0
212.159.6.9 17.44/17.78/18.36/0.31/0
212.159.6.10 17.02/17.59/18.30/0.46/0
212.159.13.49 17.04/18.18/19.41/0.92/0
212.159.13.50 17.01/17.53/17.89/0.30/0
208.67.222.222 17.08/17.64/18.81/0.63/0
208.67.222.220 17.09/17.47/17.66/0.20/0
208.67.222.123 17.11/17.54/18.40/0.47/0
208.67.220.123 17.11/17.31/17.51/0.14/0
8.8.8.8 22.51/22.90/23.14/0.24/0
8.8.4.4 22.51/22.81/23.05/0.21/0
4.2.2.1 17.02/17.25/17.47/0.19/0
4.2.2.6 16.81/17.03/17.27/0.19/0
What gateway are you on atm, i'm just qurious, I see your point with the software though
Re: Dns seems high
17-09-2013 10:09 PM
Anyway, I appreciate the reference point. What's your ping to www.bbc.co.uk? That's pretty much the lowest you're going to get to a public website, since PlusNet have a direct link. It establishes a scale for everything else.
My ping to there flickers between 4 & 5 ms. (It's 3ms when things are good!)
By contrast, ping to 212.159.6.10 is currently between 4 and 7 ms, up and down all over the place over only 20 pings, and 212.159.6.9 varies between 4 and 19 ms during the same 20 pings.
This is what a selection of nameserver cached responses looks like at one moment in time (10 queries, as usual, and slower now than the 40% degradation I quoted earlier - if BBC ping is 3ms, the figures are 5.xxms):
[tt]Nameserver Response Time (ms)
212.159.6.9 7.06/9.81/12.03/1.65/0
212.159.6.10 8.06/10.21/13.20/1.72/0
212.159.13.49 8.08/9.89/12.36/1.54/0
212.159.13.50 8.23/9.07/9.90/0.73/0
208.67.222.222 7.27/9.15/11.29/1.45/0
208.67.220.220 7.14/7.87/8.73/0.57/0
198.153.192.50 8.47/9.10/9.92/0.58/0
198.153.194.50 15.30/16.27/17.74/0.90/0
8.8.8.8 13.24/15.09/16.85/1.32/0
8.8.4.4 13.91/14.37/15.75/0.71/0
4.2.2.1 7.48/8.45/10.86/1.22/0
4.2.2.6 7.77/8.59/10.03/0.77/0[/tt]
I'm on ptn-ag03
Re: Dns seems high
17-09-2013 10:50 PM
PING bbc.co.uk (212.58.251.195) 56(84) bytes of data.
64 bytes from www-vip.telhc.bbc.co.uk (212.58.251.195): icmp_req=1 ttl=119 time=17.7 ms
64 bytes from www-vip.telhc.bbc.co.uk (212.58.251.195): icmp_req=2 ttl=119 time=17.6 ms
64 bytes from www-vip.telhc.bbc.co.uk (212.58.251.195): icmp_req=3 ttl=119 time=17.1 ms
64 bytes from www-vip.telhc.bbc.co.uk (212.58.251.195): icmp_req=4 ttl=119 time=17.4 ms
64 bytes from www-vip.telhc.bbc.co.uk (212.58.251.195): icmp_req=5 ttl=119 time=17.6 ms
64 bytes from www-vip.telhc.bbc.co.uk (212.58.251.195): icmp_req=6 ttl=119 time=17.7 ms
64 bytes from www-vip.telhc.bbc.co.uk (212.58.251.195): icmp_req=7 ttl=119 time=17.3 ms
64 bytes from www-vip.telhc.bbc.co.uk (212.58.251.195): icmp_req=8 ttl=119 time=17.1 ms
64 bytes from www-vip.telhc.bbc.co.uk (212.58.251.195): icmp_req=9 ttl=119 time=17.2 ms
64 bytes from www-vip.telhc.bbc.co.uk (212.58.251.195): icmp_req=10 ttl=119 time=17.2 ms
64 bytes from www-vip.telhc.bbc.co.uk (212.58.251.195): icmp_req=11 ttl=119 time=17.4 ms
64 bytes from www-vip.telhc.bbc.co.uk (212.58.251.195): icmp_req=12 ttl=119 time=17.3 ms
64 bytes from www-vip.telhc.bbc.co.uk (212.58.251.195): icmp_req=13 ttl=119 time=17.6 ms
64 bytes from www-vip.telhc.bbc.co.uk (212.58.251.195): icmp_req=14 ttl=119 time=17.2 ms
64 bytes from www-vip.telhc.bbc.co.uk (212.58.251.195): icmp_req=15 ttl=119 time=17.5 ms
64 bytes from www-vip.telhc.bbc.co.uk (212.58.251.195): icmp_req=16 ttl=119 time=17.5 ms
64 bytes from www-vip.telhc.bbc.co.uk (212.58.251.195): icmp_req=17 ttl=119 time=17.0 ms
64 bytes from www-vip.telhc.bbc.co.uk (212.58.251.195): icmp_req=18 ttl=119 time=17.2 ms
64 bytes from www-vip.telhc.bbc.co.uk (212.58.251.195): icmp_req=19 ttl=119 time=17.5 ms
64 bytes from www-vip.telhc.bbc.co.uk (212.58.251.195): icmp_req=20 ttl=119 time=17.2 ms
64 bytes from www-vip.telhc.bbc.co.uk (212.58.251.195): icmp_req=21 ttl=119 time=17.2 m
64 bytes from www-vip.telhc.bbc.co.uk (212.58.251.195): icmp_req=22 ttl=119 time=17.8 ms
64 bytes from www-vip.telhc.bbc.co.uk (212.58.251.195): icmp_req=23 ttl=119 time=17.7 ms
^C
--- bbc.co.uk ping statistics ---
23 packets transmitted, 23 received, 0% packet loss, time 22034ms
rtt min/avg/max/mdev = 17.035/17.444/17.872/0.276 ms
Re: Dns seems high
17-09-2013 11:10 PM
Well, I'm off to bed for now. But thanks. And hopefully we've given Bob food for thought too.
Re: Dns seems high
18-09-2013 8:59 AM
BBC ping up to a steady 5ms, even though traffic must be lower now...
212.159.6.9 6.91/7.01/7.15/0.09/0
212.159.6.10 6.65/7.09/7.56/0.36/0
212.159.13.49 6.90/7.07/7.24/0.12/0
212.159.13.50 6.45/6.66/6.83/0.13/0
208.67.222.222 6.69/7.08/7.72/0.36/0
208.67.220.220 6.67/6.95/7.17/0.19/0
198.153.192.50 7.14/7.25/7.37/0.09/0
198.153.194.50 14.19/14.84/15.33/0.46/0
8.8.8.8 12.61/12.86/13.35/0.26/0
8.8.4.4 12.33/12.87/14.11/0.63/0
4.2.2.1 6.51/7.30/8.19/0.57/0
4.2.2.6 6.62/6.96/7.72/0.40/0[/tt]
Re: Dns seems high
18-09-2013 3:46 PM
Quote from: SuperZoom So what's caused the higher load? Just a big traffic increase since people came back to work/school/university and stopped spending evenings outdoors?
I'm not 100% sure if I'm honest. It could simply be that we've reached a tipping point. Or a couple of the caches were upgraded fairly recently and that upset the balance between them. I'll try and find out.
Quote from: SuperZoom My ping to there flickers between 4 & 5 ms. (It's 3ms when things are good!)
Whilst I appreciate the observation, we're talking milliseconds here. I'd rarely consider anything below 19ms to be a problem.
FWIW, my pings to the beeb/caches are almost identical to 30FTTC06's.
Anyway, just popped by to say that all of the PCL caches have been done now with similar results to the graphing I included in my last post. We'll be doing the Telehouse ones next.
Re: Dns seems high
18-09-2013 4:05 PM
When the DNS is going awry, it would be useful to have a look at the current graph, rather than us posting complaints not knowing whether or not there is something wrong, followed a day later you posting the plot for the previous day.
Re: Dns seems high
18-09-2013 5:22 PM
