Disconnects - Help Please
Fixes: 244
Re: Disconnects - Help Please
If the router senses an issue it droos the line is I think hogwash. @bobpullen ?
What is fair to say is that if the DLN senses an issue it will adjust the line … around 2am. We have not seen router stats here to see what if any difference there is before/after the drops.
Now that another user in a nearby by location has reported a similar experience, Plusnet might be able to run this as a cluster issue. Wound be very interesting to see VR plots for the two accounts side by side.
superuser
No drop over night
But the connection is speed is down from what is has been for a while at near 80
to as seen in the attached
superuser
@adamwalker
@Townman
I do now have a filter so I can plug in to the test socket
Not sure if that will help now or what to do what I have
superuser
@superuser wrote:
@adamwalker
@Townman
Looking at the advice on the test socket it seems related mostly to internal wiring and other devices connected.
None of this applies to me
Fixes: 244
On some odd occasions, the face plate can introduce issues, especially if it is a filtered faceplate. Even passive ones have been known to not seat properly.
adamwalker
Fixes: 223
definitely worth a try superuser, let us know how things go with that.
 Adam Walker
superuser
The engineer returned today and I understand he has reported a fault with an underground cable, although not directly related to me it is he thinks creating cross talk, which I understand is clearly visible on my line.
For now, the issue is ongoing
And I will see if my line syncs back up to near 80 but it may take a few days, the engineer was doubtful with the cross talk he was seeing
superuser
Checked this AM
It had been off at 4.15AM
The line is now up to 74meg
superuser
Checked today
It's been down again around 1 or 2 am
Now Down Stream : 75637Kbps
Will get to the test socket asap
Just very busy
csmith94
Fixes: 31
Hi @superuser
How you been finding the connection/speeds today?
- Curtis, Plusnet Sheffield
 Curtis Smith
superuser
@csmith94
Speeds are up to max
They were on the job most of the day yesterday, Monday 23rd
I see my line dropped though last night around 10pm, I would be in bed though
Anyway openreach know there issues with the network that need repair but they think it should be improved for me now.
Issues such a line repairs, where they really need replacing.
I'm just waiting to see what happens now
superuser
It was down again around 1am overnight
But
Connected : Down Stream : 79997Kbps / Up Stream : 13409Kbps
Fixes: 244
So the current situation is that
  1. The line speed is at the top of the envelope
  2. The link drops during hours when you are not using it
  3. The link reconnects quickly, at the same high speeds
Is that correct?
So long as 1 & 3 remain as they are and there are no drops during the time you need to use the internet, what remains the operational issue?
superuser
@Townman
1. Correct
2. Mostly, but it does happen during use, but less frequently
3. It takes about 10 min to come back, the CAB has older technology I understand
The issue? Is regular line drops normal - No
Am I fussy. Possibly. But when it drops in a conference/zoom meeting it's not so funny. I don't mean in a business sense
superuser
Slow as treacle
Really slow today.
Just seems like issue after issue. And I still get disconnects regularly to as per this thread
https://community.plus.net/t5/Broadband/Disconnects-Help-Please/m-p/1907289#M354518
