Disconnects - Help Please
Fixes: 1,662
Re: Disconnects - Help Please
No problem! Are you still having issues or all good now?
Having a quick look at your connection, I can see it's been up for 5 days straight.
superuser
Yeah
Thank you
It seems okay for now
Really appreciate Plusnet service
Fixes: 1,662
Awesome! No worries at all, happy to help.
Let me know if there's anything else you'd need help with
superuser
Now you mention it
Not that it's a massive issue
But the speeds I get are under 50 down
My Cab is less than 100m away
Here I think
Cabinet P1   FTTC Available from 19th March 2016   Phase BDUK HIE 14a    377   Huawei   PA30 8AB
Router info
SNR Margin
8.6 dB
4.5 dB
Line Attenuation
10.4 dB
20.5 dB
Fixes: 1,662
Testing your line's not showing any issues but I can see your speed is below the estimated speed range for your line which our suppliers make out to be between 59mbps to 80mbps. I'll be happy to arrange an engineer visit to take a closer look.
If you're okay with this, when could you be available?
The engineers work weekday timeslots and occasionally Saturday's of 8am to 1pm or 1pm to 6pm.
superuser
I'm in on Monday next week
Fixes: 1,662
Okay cool. I've arranged the engineer visit for Monday 24th October 8am to 1pm. There's a small chance it won't go ahead then due to industrial action (strikes) but I'll have a look tomorrow to check if the appointment's confirmed.
Fixes: 1,662
The engineer appointment's confirmed for 24/10/22 8am to 1pm Smiley
Let us know how it goes.
superuser
No one turned up
Fixes: 1,662
Really sorry to hear this. Sad
Many engineers were on strike today so it's likely the engineers who were left couldn't get through all their work.
Openreach should be contacting you within the next couple of days to rearrange the appointment.
Fixes: 387
Deleted
superuser
An appointment went ahead yesterday 27th
The engineer tested the house first and found no issues. Said it must be at the cabinet.
Finally came back and said it must be my router.
So the house was OK
But suddenly it's the router. This I doubt. But I have two other new routers, a Draytek and a Billion
I will try them next week when I have some time free.
superuser
So the house was OK
Oh, yes. It's apparently 20% down on what it should be
TheMightyAJ
Fixes: 126
Hey @superuser,
Thanks for getting back in touch. Please let us know how the connection performs with one of the alternate routers set up and we'll be happy to review this with you further. To set up the other routers you'll need to enter the right authentication settings - if you need a hand with this, just drop us another message and we'll be happy to help Smiley
 Alex H
superuser
Current router
Asus DSL-AC68U
 DOWNLOAD Mbps
49.38
 UPLOAD Mbps
11.88
It will be next week before I can swap them
