Disconnected because idle timeout reached
theograham1612
Hey guys and gals,
Just had a disconnection last night and the last error message was "Disconnected because idle timeout reached"
The broadband light was still going but the internet light was red. My router is the bog standard one from PN.
Anyway know how to stop this happening in the future?
Cheers
9 REPLIES 9
Jaggies
Re: Disconnected because idle timeout reached
You need to set the Idle Timeout period in the router to 0 (zero). You'll need to let us know which router you are using if you don't know where to find the setting. If it's already at zero, then something else is wrong.
theograham1612
Hi Jaggies,
I'm using the Technicolour TG582N router.
Pettitto
Fixes: 5
Have you made any changes to the Idle Timeout function on the router?
theograham1612
I think I had set it to zero last night.
Pettitto
Fixes: 5
Did this cause your connection to drop or was you able to continue using the service as normal?
theograham1612
I think it was not long after it that the connection dropped.
Aspiring Hero
Fixes: 74
Post removed..
Pettitto
Fixes: 5
Let us know if this happens again as it appears to have been a one-off?
theograham1612
I'll keep a look out.
