Upload speed 600kbps
Fixes: 19
With an upload speed of 600kbps... how long should it take to upload 5 pics to the forum,  with a total size of just under 500 kb ?
Fixes: 20
Re: Upload speed 600kbps
It would probably take less than one minute, if you check the forums in another tab, various past threads have raised the issue.
When uploading to this forum what I do is, click Post then open a new tab for the section the thread is in, then I refresh that tab until I see my post.  Then I close the existing tab which usually does not get updated due to this buggy forum.
Unvalued customer since 2001 funding cheap internet for others / DSL/Fibre house move 24 month regrade from 8th May 2017
