Deterioration in Speed
sdhuk
Hello,
My broadband speed is gradually deteriorating as you can see from the attached chart.
Troubleshooting info from my hub below:
6. Data rate:15642 / 51131
7. Maximum data rate:15642 / 53856
8. Noise margin:6.0 / 6.1
9. Line attenuation:27.1 / 20.2
10. Signal attenuation:26.9 / 20.2
Any advice on how to improve things would be appreciated - thanks!
Stuart
43 REPLIES 43
Fixes: 357
Re: Deterioration in Speed
@sdhuk Welcome to the forums.
BT Broadband(obscuring your phone number) and BTW Performance Tester - Over a wired (ethernet) connection if at all possible, please report the 'ADDITIONAL DIAGNOSTICS', and sight of the broadband connection status from your Hub would be a good starting point.
For the Hub One -
For the Hub Two -
If phone test is OK then take the front off your telephone master socket, you may need to remove two screws. In behind you will find the test socket. Plug a filter in here and connect that to your hub. If it’s still dropping out then report a fault at https://faults.plus.net.
Fixes: 466
Moderators Note
This topic has been moved from Full Fibre to Broadband
sdhuk
Thanks for this.
Quiet line test is fine.
Please see the requested test in the attached files (unfortunately I don't seem to be able to inset images in line with the text in my reply. The BTW 'additional diagnostic' unfortunately wouldn't run for me either.
Thank you,
Stuart
Fixes: 357
Thanks for the shots. To take them in order (top-bottom): can you please re-run the BTW speed test - that one is an obvious rogue.
The Help Desk shot gives rise to one observation - I assume you do not intentionally disconnect the Hub? - your DSL connection time is only just over seven days, which suggests to me there is a fault/problem somewhere in the network.
The availability checker indicates you should be getting better than you are, as your final screen shot indicates you have been doing in the past.
As well as re-running the speed test, can you post the WAN logs from your event log, please.
sdhuk
Thank you again!
I don't intentionally disconnect my router.
I've re-run the BTW test. The upload seem accurate, but I don't seem to be able to get a sensible download result from it.
WAN log below:
10:11:53, 06 Aug.( 133.230000) WAN operating mode is VDSL
10:11:53, 06 Aug.( 133.230000) Last WAN operating mode was VDSL
10:11:51, 06 Aug.( 132.010000) PPP IPCP Receive Configuration ACK
10:11:51, 06 Aug.( 132.010000) PPP IPCP Send Configuration Request
10:11:51, 06 Aug.( 132.000000) PPP IPCP Receive Configuration NAK
10:11:51, 06 Aug.( 132.000000) PPP IPCP Send Configuration ACK
10:11:51, 06 Aug.( 132.000000) PPP IPCP Receive Configuration Request
10:11:51, 06 Aug.( 131.990000) PPP IPCP Send Configuration Request
10:11:50, 06 Aug.( 130.960000) PPPoE is up -​ Down Rate=51131Kbps, Up Rate=15642Kbps; SNR Margin Down=6.1dB, Up=6.1dB
10:11:50, 06 Aug.( 130.950000) CHAP authentication successful
10:11:50, 06 Aug.( 130.890000) CHAP Receive Challenge
10:11:50, 06 Aug.( 130.890000) Starting CHAP authentication with peer
10:11:50, 06 Aug.( 130.890000) PPP LCP Receive Configuration ACK
10:11:50, 06 Aug.( 130.880000) PPP LCP Send Configuration Request
10:11:50, 06 Aug.( 130.880000) PPP LCP Receive Configuration Reject
10:11:50, 06 Aug.( 130.880000) PPP LCP Send Configuration ACK
10:11:50, 06 Aug.( 130.870000) PPP LCP Receive Configuration Request
10:11:50, 06 Aug.( 130.870000) PPP LCP Send Configuration Request
10:11:01, 06 Aug.( 81.760000) PTM over DSL is up
10:10:14, 06 Aug.( 34.180000) WAN Auto-​sensing running.
10:05:08, 06 Aug.( 136.960000) WAN operating mode is VDSL
10:05:08, 06 Aug.( 136.960000) Last WAN operating mode was VDSL
10:05:07, 06 Aug.( 135.810000) PPP IPCP Receive Configuration ACK
10:05:07, 06 Aug.( 135.800000) PPP IPCP Send Configuration Request
10:05:07, 06 Aug.( 135.790000) PPP IPCP Receive Configuration NAK
10:05:07, 06 Aug.( 135.790000) PPP IPCP Send Configuration ACK
10:05:07, 06 Aug.( 135.790000) PPP IPCP Receive Configuration Request
10:05:07, 06 Aug.( 135.790000) PPP IPCP Send Configuration Request
10:05:06, 06 Aug.( 134.790000) PPPoE is up -​ Down Rate=50758Kbps, Up Rate=15660Kbps; SNR Margin Down=6.1dB, Up=6.1dB
10:05:06, 06 Aug.( 134.780000) CHAP authentication successful
10:05:06, 06 Aug.( 134.730000) CHAP Receive Challenge
10:05:06, 06 Aug.( 134.730000) Starting CHAP authentication with peer
10:05:06, 06 Aug.( 134.730000) PPP LCP Receive Configuration ACK
10:05:06, 06 Aug.( 134.720000) PPP LCP Send Configuration Request
10:05:06, 06 Aug.( 134.720000) PPP LCP Receive Configuration Reject
10:05:06, 06 Aug.( 134.720000) PPP LCP Send Configuration ACK
10:05:06, 06 Aug.( 134.720000) PPP LCP Receive Configuration Request
10:04:17, 06 Aug.( 85.680000) PTM over DSL is up
10:03:26, 06 Aug.( 34.870000) WAN Auto-​sensing running.
02:38:05, 01 Aug.(3515832.360000) WAN operating mode is VDSL
02:38:05, 01 Aug.(3515832.360000) Last WAN operating mode was VDSL
02:38:04, 01 Aug.(3515830.960000) PPP IPCP Receive Configuration ACK
02:38:04, 01 Aug.(3515830.960000) PPP IPCP Send Configuration Request
02:38:04, 01 Aug.(3515830.950000) PPP IPCP Receive Configuration NAK
02:38:04, 01 Aug.(3515830.950000) PPP IPCP Send Configuration ACK
02:38:04, 01 Aug.(3515830.940000) PPP IPCP Receive Configuration Request
02:38:04, 01 Aug.(3515830.940000) PPP IPCP Send Configuration Request
02:38:03, 01 Aug.(3515829.730000) PPPoE is up -​ Down Rate=50113Kbps, Up Rate=15307Kbps; SNR Margin Down=6.1dB, Up=6.1dB
02:38:03, 01 Aug.(3515829.720000) CHAP authentication successful
02:38:02, 01 Aug.(3515829.630000) CHAP Receive Challenge
02:38:02, 01 Aug.(3515829.630000) Starting CHAP authentication with peer
02:38:02, 01 Aug.(3515829.620000) PPP LCP Receive Configuration ACK
02:38:02, 01 Aug.(3515829.620000) PPP LCP Send Configuration Request
02:38:02, 01 Aug.(3515829.610000) PPP LCP Receive Configuration Reject
02:38:02, 01 Aug.(3515829.610000) PPP LCP Send Configuration ACK
02:38:02, 01 Aug.(3515829.610000) PPP LCP Receive Configuration Request
02:38:02, 01 Aug.(3515829.610000) PPP LCP Send Configuration Request
02:37:13, 01 Aug.(3515779.930000) PTM over DSL is up
02:36:36, 01 Aug.(3515743.480000) PTM over DSL is down after 1001 minutes uptime
02:36:36, 01 Aug.(3515743.470000) PPPoE is down after 1000 minutes uptime [Waiting for Underlying Connection (WAN Ethernet 7 -​ Down)]
02:36:33, 01 Aug.(3515740.480000) PPP LCP Send Termination Request [User request]
09:55:59, 31 Jul.(3455706.770000) WAN operating mode is VDSL
09:55:59, 31 Jul.(3455706.770000) Last WAN operating mode was VDSL
09:55:58, 31 Jul.(3455705.360000) PPP IPCP Receive Configuration ACK
09:55:58, 31 Jul.(3455705.350000) PPP IPCP Send Configuration Request
09:55:58, 31 Jul.(3455705.340000) PPP IPCP Receive Configuration NAK
09:55:58, 31 Jul.(3455705.340000) PPP IPCP Send Configuration ACK
09:55:58, 31 Jul.(3455705.340000) PPP IPCP Receive Configuration Request
09:55:58, 31 Jul.(3455705.330000) PPP IPCP Send Configuration Request
09:55:56, 31 Jul.(3455704.110000) PPPoE is up -​ Down Rate=54877Kbps, Up Rate=15564Kbps; SNR Margin Down=6.2dB, Up=6.3dB
09:55:56, 31 Jul.(3455704.090000) CHAP authentication successful
09:55:56, 31 Jul.(3455704.030000) CHAP Receive Challenge
09:55:56, 31 Jul.(3455704.030000) Starting CHAP authentication with peer
09:55:56, 31 Jul.(3455704.020000) PPP LCP Receive Configuration ACK
09:55:56, 31 Jul.(3455704.020000) PPP LCP Send Configuration Request
09:55:56, 31 Jul.(3455704.010000) PPP LCP Receive Configuration Reject
09:55:56, 31 Jul.(3455704.010000) PPP LCP Send Configuration ACK
09:55:56, 31 Jul.(3455704.010000) PPP LCP Receive Configuration Request
09:55:56, 31 Jul.(3455704.010000) PPP LCP Send Configuration Request
09:55:07, 31 Jul.(3455654.320000) PTM over DSL is up
09:54:29, 31 Jul.(3455617.070000) PTM over DSL is down after 11902 minutes uptime
09:54:29, 31 Jul.(3455617.070000) PPPoE is down after 11901 minutes uptime [Waiting for Underlying Connection (WAN Ethernet 7 -​ Down)]
09:54:26, 31 Jul.(3455614.070000) PPP LCP Send Termination Request [User request]
03:32:42, 23 Jul.(2741515.490000) WAN operating mode is VDSL
03:32:42, 23 Jul.(2741515.490000) Last WAN operating mode was VDSL
03:32:41, 23 Jul.(2741514.080000) PPP IPCP Receive Configuration ACK
03:32:41, 23 Jul.(2741514.080000) PPP IPCP Send Configuration Request
03:32:41, 23 Jul.(2741514.070000) PPP IPCP Receive Configuration NAK
03:32:41, 23 Jul.(2741514.070000) PPP IPCP Send Configuration ACK
03:32:41, 23 Jul.(2741514.060000) PPP IPCP Receive Configuration Request
03:32:41, 23 Jul.(2741514.060000) PPP IPCP Send Configuration Request
03:32:40, 23 Jul.(2741512.860000) PPPoE is up -​ Down Rate=55312Kbps, Up Rate=15818Kbps; SNR Margin Down=6.0dB, Up=5.9dB
03:32:40, 23 Jul.(2741512.840000) CHAP authentication successful
03:32:40, 23 Jul.(2741512.770000) CHAP Receive Challenge
03:32:40, 23 Jul.(2741512.770000) Starting CHAP authentication with peer
03:32:40, 23 Jul.(2741512.770000) PPP LCP Receive Configuration ACK
03:32:40, 23 Jul.(2741512.760000) PPP LCP Send Configuration Request
03:32:40, 23 Jul.(2741512.760000) PPP LCP Receive Configuration Reject
03:32:40, 23 Jul.(2741512.760000) PPP LCP Send Configuration ACK
sdhuk
Thank you for this.
I don't intentionally disconnect my Hub, so perhaps there is a fault somewhere?
I've tried to run the BTW test several times. The upload is representative, but the download can be anything between 90Mbps to 150 Mbps. I've attached another screenshot.
WAN logs below:
10:11:53, 06 Aug. ( 133.230000) WAN operating mode is VDSL
10:11:53, 06 Aug. ( 133.230000) Last WAN operating mode was VDSL
10:11:51, 06 Aug. ( 132.010000) PPP IPCP Receive Configuration ACK
10:11:51, 06 Aug. ( 132.010000) PPP IPCP Send Configuration Request
10:11:51, 06 Aug. ( 132.000000) PPP IPCP Receive Configuration NAK
10:11:51, 06 Aug. ( 132.000000) PPP IPCP Send Configuration ACK
10:11:51, 06 Aug. ( 132.000000) PPP IPCP Receive Configuration Request
10:11:51, 06 Aug. ( 131.990000) PPP IPCP Send Configuration Request
10:11:50, 06 Aug. ( 130.960000) PPPoE is up -​ Down Rate=51131Kbps, Up Rate=15642Kbps; SNR Margin Down=6.1dB, Up=6.1dB
10:11:50, 06 Aug. ( 130.950000) CHAP authentication successful
10:11:50, 06 Aug. ( 130.890000) CHAP Receive Challenge
10:11:50, 06 Aug. ( 130.890000) Starting CHAP authentication with peer
10:11:50, 06 Aug. ( 130.890000) PPP LCP Receive Configuration ACK
10:11:50, 06 Aug. ( 130.880000) PPP LCP Send Configuration Request
10:11:50, 06 Aug. ( 130.880000) PPP LCP Receive Configuration Reject
10:11:50, 06 Aug. ( 130.880000) PPP LCP Send Configuration ACK
10:11:50, 06 Aug. ( 130.870000) PPP LCP Receive Configuration Request
10:11:50, 06 Aug. ( 130.870000) PPP LCP Send Configuration Request
10:11:01, 06 Aug. ( 81.760000) PTM over DSL is up
10:10:14, 06 Aug. ( 34.180000) WAN Auto-​sensing running.
10:05:08, 06 Aug. ( 136.960000) WAN operating mode is VDSL
10:05:08, 06 Aug. ( 136.960000) Last WAN operating mode was VDSL
10:05:07, 06 Aug. ( 135.810000) PPP IPCP Receive Configuration ACK
10:05:07, 06 Aug. ( 135.800000) PPP IPCP Send Configuration Request
10:05:07, 06 Aug. ( 135.790000) PPP IPCP Receive Configuration NAK
10:05:07, 06 Aug. ( 135.790000) PPP IPCP Send Configuration ACK
10:05:07, 06 Aug. ( 135.790000) PPP IPCP Receive Configuration Request
10:05:07, 06 Aug. ( 135.790000) PPP IPCP Send Configuration Request
10:05:06, 06 Aug. ( 134.790000) PPPoE is up -​ Down Rate=50758Kbps, Up Rate=15660Kbps; SNR Margin Down=6.1dB, Up=6.1dB
10:05:06, 06 Aug. ( 134.780000) CHAP authentication successful
10:05:06, 06 Aug. ( 134.730000) CHAP Receive Challenge
10:05:06, 06 Aug. ( 134.730000) Starting CHAP authentication with peer
10:05:06, 06 Aug. ( 134.730000) PPP LCP Receive Configuration ACK
10:05:06, 06 Aug. ( 134.720000) PPP LCP Send Configuration Request
10:05:06, 06 Aug. ( 134.720000) PPP LCP Receive Configuration Reject
10:05:06, 06 Aug. ( 134.720000) PPP LCP Send Configuration ACK
10:05:06, 06 Aug. ( 134.720000) PPP LCP Receive Configuration Request
10:04:17, 06 Aug. ( 85.680000) PTM over DSL is up
10:03:26, 06 Aug. ( 34.870000) WAN Auto-​sensing running.
02:38:05, 01 Aug. (3515832.360000) WAN operating mode is VDSL
02:38:05, 01 Aug. (3515832.360000) Last WAN operating mode was VDSL
02:38:04, 01 Aug. (3515830.960000) PPP IPCP Receive Configuration ACK
02:38:04, 01 Aug. (3515830.960000) PPP IPCP Send Configuration Request
02:38:04, 01 Aug. (3515830.950000) PPP IPCP Receive Configuration NAK
02:38:04, 01 Aug. (3515830.950000) PPP IPCP Send Configuration ACK
02:38:04, 01 Aug. (3515830.940000) PPP IPCP Receive Configuration Request
02:38:04, 01 Aug. (3515830.940000) PPP IPCP Send Configuration Request
02:38:03, 01 Aug. (3515829.730000) PPPoE is up -​ Down Rate=50113Kbps, Up Rate=15307Kbps; SNR Margin Down=6.1dB, Up=6.1dB
02:38:03, 01 Aug. (3515829.720000) CHAP authentication successful
02:38:02, 01 Aug. (3515829.630000) CHAP Receive Challenge
02:38:02, 01 Aug. (3515829.630000) Starting CHAP authentication with peer
02:38:02, 01 Aug. (3515829.620000) PPP LCP Receive Configuration ACK
02:38:02, 01 Aug. (3515829.620000) PPP LCP Send Configuration Request
02:38:02, 01 Aug. (3515829.610000) PPP LCP Receive Configuration Reject
02:38:02, 01 Aug. (3515829.610000) PPP LCP Send Configuration ACK
02:38:02, 01 Aug. (3515829.610000) PPP LCP Receive Configuration Request
02:38:02, 01 Aug. (3515829.610000) PPP LCP Send Configuration Request
02:37:13, 01 Aug. (3515779.930000) PTM over DSL is up
02:36:36, 01 Aug. (3515743.480000) PTM over DSL is down after 1001 minutes uptime
02:36:36, 01 Aug. (3515743.470000) PPPoE is down after 1000 minutes uptime [Waiting for Underlying Connection (WAN Ethernet 7 -​ Down)]
02:36:33, 01 Aug. (3515740.480000) PPP LCP Send Termination Request [User request]
09:55:59, 31 Jul. (3455706.770000) WAN operating mode is VDSL
09:55:59, 31 Jul. (3455706.770000) Last WAN operating mode was VDSL
09:55:58, 31 Jul. (3455705.360000) PPP IPCP Receive Configuration ACK
09:55:58, 31 Jul. (3455705.350000) PPP IPCP Send Configuration Request
09:55:58, 31 Jul. (3455705.340000) PPP IPCP Receive Configuration NAK
09:55:58, 31 Jul. (3455705.340000) PPP IPCP Send Configuration ACK
09:55:58, 31 Jul. (3455705.340000) PPP IPCP Receive Configuration Request
09:55:58, 31 Jul. (3455705.330000) PPP IPCP Send Configuration Request
09:55:56, 31 Jul. (3455704.110000) PPPoE is up -​ Down Rate=54877Kbps, Up Rate=15564Kbps; SNR Margin Down=6.2dB, Up=6.3dB
09:55:56, 31 Jul. (3455704.090000) CHAP authentication successful
09:55:56, 31 Jul. (3455704.030000) CHAP Receive Challenge
09:55:56, 31 Jul. (3455704.030000) Starting CHAP authentication with peer
09:55:56, 31 Jul. (3455704.020000) PPP LCP Receive Configuration ACK
09:55:56, 31 Jul. (3455704.020000) PPP LCP Send Configuration Request
09:55:56, 31 Jul. (3455704.010000) PPP LCP Receive Configuration Reject
09:55:56, 31 Jul. (3455704.010000) PPP LCP Send Configuration ACK
09:55:56, 31 Jul. (3455704.010000) PPP LCP Receive Configuration Request
09:55:56, 31 Jul. (3455704.010000) PPP LCP Send Configuration Request
09:55:07, 31 Jul. (3455654.320000) PTM over DSL is up
09:54:29, 31 Jul. (3455617.070000) PTM over DSL is down after 11902 minutes uptime
09:54:29, 31 Jul. (3455617.070000) PPPoE is down after 11901 minutes uptime [Waiting for Underlying Connection (WAN Ethernet 7 -​ Down)]
09:54:26, 31 Jul. (3455614.070000) PPP LCP Send Termination Request [User request]
03:32:42, 23 Jul. (2741515.490000) WAN operating mode is VDSL
03:32:42, 23 Jul. (2741515.490000) Last WAN operating mode was VDSL
03:32:41, 23 Jul. (2741514.080000) PPP IPCP Receive Configuration ACK
03:32:41, 23 Jul. (2741514.080000) PPP IPCP Send Configuration Request
03:32:41, 23 Jul. (2741514.070000) PPP IPCP Receive Configuration NAK
03:32:41, 23 Jul. (2741514.070000) PPP IPCP Send Configuration ACK
03:32:41, 23 Jul. (2741514.060000) PPP IPCP Receive Configuration Request
03:32:41, 23 Jul. (2741514.060000) PPP IPCP Send Configuration Request
03:32:40, 23 Jul. (2741512.860000) PPPoE is up -​ Down Rate=55312Kbps, Up Rate=15818Kbps; SNR Margin Down=6.0dB, Up=5.9dB
03:32:40, 23 Jul. (2741512.840000) CHAP authentication successful
03:32:40, 23 Jul. (2741512.770000) CHAP Receive Challenge
03:32:40, 23 Jul. (2741512.770000) Starting CHAP authentication with peer
03:32:40, 23 Jul. (2741512.770000) PPP LCP Receive Configuration ACK
03:32:40, 23 Jul. (2741512.760000) PPP LCP Send Configuration Request
03:32:40, 23 Jul. (2741512.760000) PPP LCP Receive Configuration Reject
03:32:40, 23 Jul.
Fixes: 357
Thanks for the WAN log - it confirms my fears - there is a fault in the BT/OR network somewhere which is causing you to lose xDSL connection. Strangely enough, although it is the cause of your reducing speed, it is not accompanied by the rise in D/S SNR which I would expect.
Looks like we'll have to forget that speed tester - it is obviously borked - again.
As a mere Community member, there is little else I can offer by way of assistance, but I suggest that you report a broadband fault, but use https://www.plus.net/help/report-a-problem/broadband/ to do so - you may get a quicker response than using the link in my original post.
Post back with the result of that report, please.
sdhuk
Thank you! I'll make contact with them now.
I'll let you know the outcome.
All the best!
Stuart
sdhuk
I was eventually called by an advisor and they have booked an engineer.
I was stunned though that they store passwords in plain text (I was asked for two digits as part of their security procedure). There is no excuse these days for storing passwords unhashed/unsalted! 😕
Fixes: 357
Glad you got the engineer booked - to be honest I was expecting you to say their response was 'NFF'.
As regards the passwords, although obviously I cannot be 100%  certain about this, I understand from conversations I have had in the past that the passwords are in a protected database, and the advisors can only see the characters they ask you for - in other words if the password is 'xcv65qpgh' and they ask for the 4th and7th character, they see ***6**p**.
Let us know the result of the engineer visit.
sdhuk
Thank you!
Yeah, I'm sure they are stored in a password protected database. But the standard for more than 20 years is that companies should only store a 'hash' of a password, never the password itself, or any part of it. The hash the result of some one-way mathematics that is performed on a password. The problem is that people reuse their passwords. So if I use the same password for Plusnet as I do for my email, and their database is hacked (happens all the time, see: https://haveibeenpwned.com), then that password can be used to access my email, which is the door to re-setting all sorts of passwords and accessing all sorts of accounts...
Anyway, that's an aside. Thank you, again, for all your help!
Stuart
Fixes: 139
Hi @sdhuk
curious to know did plusnet find an issue with your connection?
@jab1
Looking a the log sample excluding this "03:32:40, 23 Jul. (2741512.860000) PPPoE is up" message did you notice there are two PPPoE down messages and four PPPoE is up messages.
10:03:26, 06 Aug. ( 34.870000) WAN Auto-​sensing running. suggests the Hub One rebooted, from this time onwards there are only PPPoE is up messages.
Dan
Fixes: 357
@Dan_the_Van I did notice the rather strange mix of messages - a little confusing to say the least, but if the OP has seen the reduction of speed in the '2022-08-13@23.17.05' graph, then I reckon there has been previous spells of this, and if it had been happening to me - even on my 'dodgy' ADSL connection - I would have been asking questions, possibly earlier in the sequence than the OP has.
Fixes: 139
@jab1
If I understand the log messages correctly at this point
The Hub One had been up for just over 40 days since it last booted. (3515832.360000) is the number of seconds since starting.
DSL Uptime is not same up system uptime (but you already know that)
