DNS Question changing MX record
- Re: DNS Question changing MX record
14-02-2008 1:23 PM
Will plus net allow me to change my MX record?
I currently don't have a domain set up so cant see.
The reason i would like to do this is so i can setup gmail in google apps with our domain.
regards
Andrew
Message 1 of 4
(1,025 Views)
3 REPLIES 3
14-02-2008 1:29 PM
Andrew,
Are you saying that you have a domain but it isn't with us?
Message 2 of 4
(455 Views)
14-02-2008 1:34 PM
Quote from: Jameseh Andrew,
Yes, its with 123reg, however,
I haven't yet set it up with plus nets name servers, so cant see the DNS options that would be available.
I was wondering if it could be possible to change MX settings once the domain had been set-up with plus net
UPDATE: should add that i will be using plus nets webhosting aswell
Andrew
Message 3 of 4
(455 Views)
14-02-2008 1:47 PM
You can use whatever you want as your mx records.
Message 4 of 4
(455 Views)
