DLM reset
MinniMan
DLM reset
Can someone reset the DLM on my line and turn off interleaving? My speed has been stuck on 67 mbps for a while and my ping has increased.
4 REPLIES 4
adamwalker
Fixes: 223
Re: DLM reset
Hi there MinniMan, I've put that through for you and it should take effect by the end of the day on Monday at the latest. Please shout up in the meantime if there's anything else we can help with. - Adam
 Adam Walker
MinniMan
Re: DLM reset
my ping has increased more and now it's difficult for me to get into call of duty matches.
MinniMan
Re: DLM reset
@adamwalker
MinniMan
Re: DLM reset
@adamwalker
The problem is now fixed. My ping is back to normal.
