DLM reset request
RealAleMadrid
Fixes: 68
Re: DLM reset request
@jab1  I was just pointing out that the line is being restricted by banding despite Plusnet saying it isn't. If there is a line noise problem that needs to be looked at first.
Fixes: 368
@RealAleMadrid Understood - but this has only just been confirmed - I’m just surprised nobody had thought to check.
Pnnoakes
Initial line check has found no fault. I’ll have to wait now till tomorrow for the advisor call to take this further. Thanks everyone for assistance so far.
Fixes: 368
The autobot doesn't pick all faults up, but if there is noise on the line, there is definitely a fault - don't let them tell you otherwise.
Pnnoakes
Thanks @jab1. I’ll update tomorrow after the advisor call.
Pnnoakes
Glad to say this seems to be fixed following the engineer visit this morning. Fault lay with the faceplate on the master socket. New pre-filtered faceplate fitted and line noise eliminated. Line reset and back to 44mb sync. Thanks to all for your advice.
