DLM Reset
kekec
DLM Reset
Hi All,
Is there any chance i can request the a DLM reset from a member of Plusnet team please?
Wee story is, my electrician switched of the whole house power a lot few weeks ago. Obvious the DLM recognised this as an issue on the line and my router stuck on 59990 Kbps. The line is relatively new (4 years old) as Openreach pulled in a new pair of copper as the old one hit by lightning. My end is 400m from the Cabinet 1.
4 REPLIES 4
James30
Fixes: 32
Re: DLM Reset
@kekec Hiya, we haven't got access to the systems we used to have to look at stats in more detail. Would you mind us calling you or can you call us on 0800 432 0200 so we can go through everything with you?
James - Plusnet Sheffield
Accepted fix
kekec
Re: DLM Reset
@James30  Thank you so much your advise. DLM resat done at 13:37.Screenshot 2024-06-26 at 18.43.48.png
Anunnaki
Re: DLM Reset
It will be interesting to see how long it holds that download sync rate with the "SNR Margin" now at 1dB
What model of DrayTek are you using ?
kekec
Re: DLM Reset
@Anunnaki I will do an update for you after a week, but usually holds the download sync rate for months without any issue.
DrayTek Vigor2865ac
