Checking status remotely
machare
Is there a way to check the status of my broadband connection remotely by visiting the Plusnet website?
3 REPLIES 3
Oldjim
Resting Legend
Fixes: 63
Re: Checking status remotely
Nope
machare
Many thanks for the prompt reply!
npr
Fixes: 9
If on a ADSL connection, you can check your router stats from a remote location if that helps.
http://npr.me.uk/remote.html
