Checking status remotely
- Re: Checking status remotely
15-02-2014 3:30 PM
Is there a way to check the status of my broadband connection remotely by visiting the Plusnet website?
Message 1 of 4
(2,154 Views)
3 REPLIES 3
15-02-2014 3:47 PM
Nope
Message 2 of 4
(1,878 Views)
15-02-2014 3:48 PM
Many thanks for the prompt reply!
Message 3 of 4
(1,878 Views)
15-02-2014 5:04 PM
If on a ADSL connection, you can check your router stats from a remote location if that helps.
http://npr.me.uk/remote.html
Message 4 of 4
(1,878 Views)
