Changed my deal and speed falls
- Changed my deal and speed falls
- « Previous
- Next »
Re: Changed my deal and speed falls
21-01-2010 12:34 PM
Hi stathe, Your stats seem to have stablised a little now. At 21:20 last night you were still at 11db whereas at a similar time on the 18th it was down at 3db. Obviously the slightly lower synch of 1280 as against 1472 on the 18th has had some effect but the SNR variation appears to be a lot less now. Looking at the 2 Bitloading graphs ( attached ) there is not a vast difference so there's not really much that can be deduced from them. If the SNR drops again significantly then another Bitloading graph at that time might be useful but at the moment it looks like your line has stabilised somewhat albeit at a slightly reduced speed.
Message 31 of 35
(262 Views)
25-01-2010 7:33 PM
My line failed again Sunday lunch time, for no aparent reason and reconected at 500 with the resultant fall in speed, I disconnected in the evening and switched on again early morning when it reconnected at around 1300 I suppose I will just have to wait for the speed such as it is to return all anoying ,as I have no idea why this should be .My noise margin seems quite high
Message 32 of 35
(262 Views)
25-01-2010 8:11 PM
The speed has now recovered to 900+ quickly in my opinion , perhaps this is my best way to deal with this , when it fails switch off then go to bed the pub or just out !! then switch on 5 or s6 hours later . Would like to know why
Message 33 of 35
(262 Views)
25-01-2010 8:16 PM
Here are my noise margin and speed for the last half hour, it did not diconnect when it went to 0
Message 34 of 35
(262 Views)
26-01-2010 2:01 AM
The sample at zero noise margin probably reflects Routerstats being unable to contact the router for some reason, so nothing to do with the status of your connection.
David
Message 35 of 35
(262 Views)
- « Previous
- Next »
