Changed From BT to Fibre and slower connection speeds
- Changed From BT to Fibre and slower connection spe...
12-03-2014 10:26 PM
HI,
changed to plus net from BT infinity. I was expecting the speeds to be the same but they have dropped around 15mb! I was getting the full speed. can you please do a complete reset to get my speed increased to the norm.
Thank you
Thank you
Message 1 of 8
(1,131 Views)
7 REPLIES 7
Re: Changed From BT to Fibre and slower connection speeds
12-03-2014 10:55 PM
Hi jasoncollins1985m
What sort of speeds were you getting? what speeds are you getting at the moment?
Message 2 of 8
(710 Views)
14-03-2014 7:52 AM
i used to be getting between 72 and 74 now im only getting 59
thanks
thanks
Message 3 of 8
(710 Views)
14-03-2014 4:43 PM
Hi jasoncollins1985,
I've had a look into this for you and it seems like the speeds you're experiencing are correct. This drop in speeds could be due to an uptake in your cabinet or potentially a fault. Our faults team can have a look into this for you if you wish for further investigation to be carried out. For them to do this you would need to raise a fault: faults.plus.net
I'm sorry for any inconvenience caused by this.
Message 4 of 8
(710 Views)
16-03-2014 8:43 PM
can you please do a dslam reset and lower snr. my download is not 53!!
Message 5 of 8
(710 Views)
17-03-2014 12:12 PM
This isn't something that we are able to do without arranging for an engineer to do this.
Can you please raise a fault with us at http://faults.plus.net so that we have record of this on your account.
Message 6 of 8
(710 Views)
17-03-2014 12:14 PM
I did, 3 days ago.
Message 7 of 8
(710 Views)
17-03-2014 12:22 PM
Apologies - I can see the ticket now.
The ticket will be picked up today and we'll get that arranged for you.
Message 8 of 8
(710 Views)
