Ping Graph
- Ping Graph
Ping Graph
13-03-2014 1:43 PM
Also the fairly regular patterns every 6 hours or so, Why are these so regular. There had been no one using the internet at these times. WiFi is security protected. Thanks
Re: Ping Graph
13-03-2014 2:33 PM
Re: Ping Graph
13-03-2014 2:46 PM
Re: Ping Graph
13-03-2014 4:16 PM
Re: Ping Graph
13-03-2014 4:17 PM
Quote from: thesawdust the part between 6-11pm is PlusNET's doing
Not sure what you mean about 'the part between 6-11pm is PlusNET's doing'
Re: Ping Graph
13-03-2014 5:07 PM
Quote from: greshoff I have an automatic cloud backup that runs when the computer starts. Would this couse the latency spike?
It certainly could account for it. Can you try it with it off to see if there's a difference?
Re: Ping Graph
13-03-2014 7:22 PM
Re: Ping Graph
13-03-2014 7:36 PM
Re: Ping Graph
14-03-2014 7:35 AM
Re: Ping Graph
17-03-2014 12:17 PM
Re: Ping Graph
17-03-2014 12:26 PM
Re: Ping Graph
17-03-2014 12:28 PM
