Capable of higher speed but not sustained.
- Re: Capable of higher speed but not sustained.
24-04-2012 10:08 AM
Link Information
Uptime: 0 days, 12:42:39
DSL Type: G.992.5 annex A
Bandwidth (Up/Down) [kbps/kbps]: 444 / 4,850
Data Transferred (Sent/Received) [kB/kB]: 0.00 / 38.00
Output Power (Up/Down) [dBm]: 12.5 / 0.0
Line Attenuation (Up/Down) [dB]: 22.0 / 37.5
SN Margin (Up/Down) [dB]: 31.5 / 9.0
Loss of Framing (Local/Remote): 11 / 0
Loss of Signal (Local/Remote): 1 / 0
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 84 / 0
FEC Errors (Up/Down): 0 / 29,521
CRC Errors (Up/Down): 0 / 109
HEC Errors (Up/Down): 0 / 90
Download speedachieved during the test was - 3.4 Mbps
For your connection, the acceptable range of speeds is 1.2 Mbps-4 Mbps.
IP Profile for your line is - 4.28 Mbps
Iplayer's speedchecker gave a figure of 4185 kbps
Back with pics later if I can open the box.
24-04-2012 10:28 AM
24-04-2012 10:44 AM
Ive had a look inside there are two larger cable in there one comes from outside which appears to have a brown plastic coat.... the one that the red an white cables are coming out of is black....must admit I dont like fiddling it looks really delicate.
24-04-2012 10:47 AM
24-04-2012 11:02 AM
Uptime: 0 days, 13:35:07
thats as of 11 am doesnt that mean since reconnecting since 9.30 last night Ive not been disconnected ?
I remember a few years back I had a run of disconnections at night like this and I remember then thinking the weird thing was that the disconnections moved an hour when the clocks changed......
24-04-2012 11:12 AM
When you say a "run" of disconnections, do you mean several disconnections each time, or just one or two each evening for a while?
And what was the fix?
As for the time shift thing, hmmm, it does sound like the possibility of something electrical going on or off but not changing to summertime. This could all be a red herring, but shouldn't be overlooked.
When you have a moment, have a look at the brown cable outside and see where it goes, and how many junction boxex (if any) you may see. With a bit of luck it will go straight up the wall to where it joins the overhead cable to the pole with no other joints or cables connected.
As for this white box inside, it shouldn't be that delicate, otherwise it could be the source of problems. Anyway we'll wait for the pics later. I'm of for a little while.
24-04-2012 12:39 PM
I dont know if these are clear enough....
24-04-2012 12:41 PM
24-04-2012 1:20 PM
The plastic bits are nick-named jelly crimps, because they are full of silicon jelly, nice connections.
Can we have a picture of this cable from outside to try and see the detail of it's shape, and tell me does it go all the way to the pole, or does it join a round black sheathed cable anywhere at the house?
24-04-2012 1:27 PM
Quote from: Xenon It seems two cables (one black and one brown come in....
Or, indeed, can you confirm if it's two separate (single-core?) cabes and, as Anotherone suggested, a picture from outside etc.
24-04-2012 1:48 PM
24-04-2012 2:15 PM
I seem to recall the engineer was talking about the cable coming to the house being the best... Im pretty sure he said something about it being aluminiuim ?? which is no longer used. Of course I cant remember the whole of the conversation because he got a bit technical. But I definately remember him saying that cable was best.
24-04-2012 2:27 PM
Don't worry about a picture, your description is good enough. But what we need to try and be sure about, is the cable going to the pole from the eaves. Have you got an upstairs window near enough that you can look and see if it is a round cross-section black sheath? It's about 6mm in diameter IIRC.
24-04-2012 2:46 PM
I was chuffed when the engineer said the cable was best...if he'd have said it had been worst Id have asked about getting it replaced. The phones been in a good few years now.
I hate to display my ignorance again another but what's IIRC mean ?
Incidentally are we still needing the stuff to be connected to the test plate or can the face plate be replaced... I'm just worried about stuff getting knocked or dust getting in there etc.
24-04-2012 2:58 PM
Is that pole on your property or on the boundary? I take it from the house to the pole doesn't cross a roadway or path.
Does any of the cable pass through any trees?
Don't go climbing step-ladders if you aren't safe, we don't want any accidents. Got any binoculars?
Yes, you can put the boxes back together and faceplate on. Stick to using the same modem/router though and post a set of stats when you are re-connected.
