Main Plusnet website / portal login down
houlton23
Can't log into the portal/VMBU on my iPad, throwing me to plus.net/error.html (which wont load) or tells me username and password is incorrect.
Also as I am logged in on laptop, anything on plus.net domain won't load and hangs waiting for plus.net
Anyone else seeing this?
CX
Re: Main Plusnet website / portal login down
Quote from: houlton23
Yes, I either get told incorrect username/password, or the page doesn't load at all.
Edit: Now getting a proper message about the site being down for maintenance.
houlton23
Someone @plusnet knows it's broken:
Plusnet Staff
Plusnet Staff
Fixes: 5
We are currently experiencing a few issues with our internal systems which, in turn has turned off access to our website. We are having this problem investigated as we speak and look to get everything back up and running again as soon as we can.
Sorry for any inconvenience this causes you all.
Chris Pettitt
Cloud Environments Engineer
Plusnet Staff
Plusnet Staff
Fixes: 5
It looks like we are back up and running now. Smiley
Chris Pettitt
Working fine for me, now.
houlton23
Down again?
Fixes: 58
Ok here.
I think you are being a bit impatient houlton23. It's usually quite slow.
Go make a pot of tea and a few sandwiches, maybe service the car.
It'll be up eventually. Wink
Customer and Forum Moderator.
houlton23
Hmmm, getting this on two different PC's here:
(I'm talking about VMBU here, didn't make that clear enough in previous post)
EDIT: Loading again now - ignore me Wink
Fixes: 58
Yes I had that problem a few seconds ago and did a refresh with success.
Just tried it again and it seems back to normal.
Fixes: 47
We're not aware of any issues guys, but thanks for pointing that out I'll reply back here if we spot anything further.
 Adam Walker
