Capable of higher speed but not sustained.
- Re: Capable of higher speed but not sustained.
23-04-2012 2:19 PM
23-04-2012 2:51 PM
You can put the back plate back on the box if you haven't already, stay plugged into the test socket for the moment.
Uploading pictures, or any attachment is easy. If you use the Reply button immediately below the last post rather than the Quick Reply box, there is a button + Additional Options and Attachment.. click on that and there is a box to browse to the file saved on your computer. That same button will also appear if you do a Preview of your post having used the Quick Reply option. You can also edit a post and amend it or add corrections or attachments if you forgot something by using the 'Modify' button just above the post.
Re: iPlayer, Bullet suggested downloading some programmes to do a test, but I pointed out that uses lots of usage allowance. If you click on the link I gave, you'll see how useful it is!
In your next post can you also post the current ADSL modem/router line stats, don't need any other tests at this moment.
23-04-2012 3:12 PM
23-04-2012 3:14 PM
Uptime: 0 days, 4:31:40
DSL Type: G.992.5 annex A
Bandwidth (Up/Down) [kbps/kbps]: 444 / 6,335
Data Transferred (Sent/Received) [kB/kB]: 0.00 / 13.00
Output Power (Up/Down) [dBm]: 12.0 / 0.0
Line Attenuation (Up/Down) [dB]: 22.0 / 38.0
SN Margin (Up/Down) [dB]: 31.0 / 6.0
Loss of Framing (Local/Remote): 11 / 0
Loss of Signal (Local/Remote): 1 / 0
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 56 / 0
FEC Errors (Up/Down): 0 / 137,540
CRC Errors (Up/Down): 0 / 129
HEC Errors (Up/Down): 0 / 111
Taken at 15.14
23-04-2012 3:17 PM
For your connection, the acceptable range of speeds is 2 Mbps-7.15 Mbps.
IP Profile for your line is - 5.59 Mbps
Taken at 15.17
23-04-2012 4:01 PM
Latest stats not too bad. I'm hoping Jojo will come and kick your Current line speed shortly, but I know she's up to her neck in it!
Will that splitter plug into the filter, so that you can connect both phones?
23-04-2012 4:33 PM
23-04-2012 4:45 PM
23-04-2012 5:08 PM
Link Information
Uptime: 0 days, 6:18:38
Data Transferred (Sent/Received) [kB/kB]: 0.00 / 19.00
SN Margin (Up/Down) [dB]: 31.5 / 6.0
Error Seconds (Local/Remote): 59 / 0
FEC Errors (Up/Down): 0 / 190,555
CRC Errors (Up/Down): 0 / 336
HEC Errors (Up/Down): 0 / 302
and heres the reading with both phones connected as per the photos below
Link Information
Uptime: 0 days, 6:21:11
FEC Errors (Up/Down): 0 / 191,348
CRC Errors (Up/Down): 0 / 338
HEC Errors (Up/Down): 0 / 304
23-04-2012 5:16 PM
Download speedachieved during the test was - 3.19 Mbps
Taken at 17.15 approx.
23-04-2012 5:43 PM
I've adjusted your profile to match your BT profile. You should see the increase shortly.
Jojo
23-04-2012 5:48 PM
Link Information
Uptime: 0 days, 7:04:56
Data Transferred (Sent/Received) [kB/kB]: 0.00 / 21.00
FEC Errors (Up/Down): 0 / 223,033
CRC Errors (Up/Down): 0 / 378
HEC Errors (Up/Down): 0 / 339
Readings taken approx 17.47 after service restored..
23-04-2012 5:52 PM
Quote from: Joanne Hi Xenon,
Jojo
Ahhhhh thanks !! I was so quick posting the figures for Another I didnt see this that presumably accounts for the disconnect....
23-04-2012 5:54 PM
23-04-2012 5:55 PM
