Cannot get to this site
- Re: Cannot get to this site
29-02-2008 11:22 AM
Please ignore - now works
I have been trying to get to www.newforestramblers.org.uk but failing and the tracert gives this result
Quote C:\Users\James>tracert www.newforestramblers.org.uk
Tracing route to newforestramblers.org.uk [213.166.17.51]
over a maximum of 30 hops:
1 <1 ms <1 ms <1 ms 192.168.0.1
2 37 ms 36 ms 36 ms lo0.plusnet.thn-ag1.plus.net [195.166.128.101]
3 36 ms 36 ms 35 ms vl703.thn-gw2.plus.net [84.92.4.242]
4 34 ms 35 ms 35 ms 10ge-6-0-0.lon11.ip.tiscali.net [213.200.78.69]
5 36 ms 36 ms 41 ms e1-7.cx2.lon1.synetrix-gw1.arbinet.net [213.232.
65.105]
6 * * * Request timed out.
7 * * * Request timed out.
8 * * * Request timed out.
Message 1 of 6
(1,367 Views)
5 REPLIES 5
29-02-2008 11:24 AM
Working very quickly here Tracert to follow
Lied, no tracert to follow at all - forgot I don't allow those through the firewall ATM (I will get round to allowing them one day I promise!)
Message 2 of 6
(560 Views)
29-02-2008 11:25 AM
Just checked and got straight in?
M
Just checked and tracert fails in a similar way as Oldjim.
M
M
M
Message 3 of 6
(560 Views)
29-02-2008 11:25 AM
Site loads very quickly here (virgin media, bt central, plusnet) although tracerts are failing. Is it possible site / next hop is dropping the ICMP packets?
Message 4 of 6
(560 Views)
29-02-2008 11:27 AM
Now works here as well - but tracert still fails
Message 5 of 6
(560 Views)
29-02-2008 11:33 AM
The trace failure is perfectly normal. It just means the hosting server or some router further up the line is ignoring / blocking tracert/ping ICMP packets.
Message 6 of 6
(560 Views)
