Cannot connect to internet.
- Cannot connect to internet.
24-09-2009 1:20 PM
I am new to broadband and used it for the first time yesterday and after connecting I did a couple of speed tests and the Bt test and everything was fine and as expected.
Then after 10 minutes I made the mistake of switching off the pc, not the router, for a couple of hours. When I switched back on I couldn't get the pc to connect to the router by wireless or cable, so I returned the router to factory settings and then inputed all the details and rebooted.
That fixed it and I can ping the router by wireless and cable, but I cannot get on the internet.
The router Dlink G624T shows green lights on power/ adsl/ wlan/ status flashes (correct) Router wire connected to filter and test socket. Telephone working. Run the inital status check on the website (using different connection) for my phone number/account, all green ticks.
The router is s/hand but it did work yesterday and the adsl light is green. Still in the 10 day training period.
Any ideas for me to try, I wonder if the wrong username or similar would cause this.
Re: Cannot connect to internet.
24-09-2009 2:14 PM
ipconfig /all
and paste the results here.
24-09-2009 3:15 PM
I have had a look further on the check website past the initial checks section, and have used the Plusnet test login details and with these have been able to connect to their test webpage.
I have reported this and further checks are now being made..
24-09-2009 3:38 PM
If you like I'll try dialtesting from here as that will help narrow where the fault lies.
24-09-2009 7:19 PM
I regret the previous info was incorrect, I didn't realize I had mobile broadband running in the background, that why the page connected.
I have rerun the tests and cannot connect to the pages using bt_test_user@plusdsl.net and bt_test@startup_domain, the test have completed with this result.
"Test result summary: Inconclusive
We have not been able to complete the checks of your broadband service.
This may be the result of a fault in the testing system rather than your service."
Can you please look into this further, could it be a router failure (adsl light green)
Can you send me a password reminder
thank you (fire ****)
24-09-2009 7:29 PM
From the web interface http://192.168.1.1 or http://192.168.0.1
> "Status" Tab at the top
> "DSL Status" from the left Menu
Default username login "admin" password "admin".
Can you see if the router is connected to the internet - if it is you should see upstream and downstream speeds as well as attenuation and noise margin.
This is not the same as connecting to Plusnet but only to the exchange
25-09-2009 10:46 AM
D U
Snr 9 17
Att'tion 49 30
DataRt 4224 448
These may have been generated previously when I did get online wednesday, as per my first post.
Using the cable rather than wireless I have pinged the bbc and 208.67.220.220 with the results show no loss for the first hop (my router) and the last, but those in between "no responce from host"
I don't know whether I can rule out a router fault, as I have no idea of its history.
25-09-2009 11:35 AM
It should show something like this
C:\Users\James>tracert 212.159.13.50
Tracing route to pth-cdns02.plus.net [212.159.13.50]
over a maximum of 30 hops:
1 <1 ms <1 ms <1 ms 192.168.0.1
2 39 ms 39 ms 38 ms lo0.plusnet.thn-ag1.plus.net [195.166.128.101]
3 38 ms 37 ms 39 ms vl703.thn-gw1.plus.net [84.92.4.241]
4 40 ms 38 ms 43 ms ae0-102.ptn-gw01.plus.net [212.159.1.53]
5 40 ms 39 ms 38 ms vl55.ptn-lb01.plus.net [212.159.2.124]
6 38 ms 40 ms 41 ms pth-cdns02.plus.net [212.159.13.50]
Trace complete.
25-09-2009 12:59 PM
1 <1ms <1ms <1ms 192.168.1.1
2 request timed out
3 "
4 "
5 <30ms <31ms <36ms pth-cdns02.plus.net [212.159.13.50]
25-09-2009 1:11 PM
25-09-2009 1:20 PM
Mind PMing me your username? I don't seem to be able to locate your account.
25-09-2009 3:45 PM
25-09-2009 5:34 PM
I notice if I ping 212.159.13.50 directly it goes straight to it as normal with these times.
min= 28 max= 74 avg= 43
25-09-2009 5:47 PM
the also knowen as is the name most useful ie thn-ag2
25-09-2009 6:01 PM
If I ping that address, no responce from host
