Can you turn on Interleaving Please
Alex2x
Just as the subject says, I'm getting disconnections to many times now, but to be honest I don't see why I have to put up with poor ping with interleaving because my connection isn't stable.
35 REPLIES 35
chrispurvey
Re: Can you turn on Interleaving Please
I've placed a modify order to turn interleaving on, let me know how you get on with it.
It will complete tomorrow for you.
Alex2x
Thank you.
Alex2x
Has the interleaving been turn on yet. the only reason I ask is that I have been disconnected again .
chrispurvey
Interleaving completed this morning so it seems your disconnection may have coincided with that.
I'd suggest monitoring it over the next few days and hopefully this will have taken effect.
Alex2x
Brilliant m8 thank you.
Alex2x
OK I'm still disconnecting, can someone please look into this, I have had an intermittent  connection since I been signed up. Don't get me wrong I'm not blaming PlusNet.
Faceplate has been replaced on master socket tried two different Routers had interleaving turned on and still having problems.
chrispurvey
Your line is looking very stable at the minute:
<img src="http://ccgi.psmith12.plus.com/visradius/generated/image13672453431147.png"/>
Are you currently connecting wired or wireless?
Alex2x
I'm using a wired connection. So is been disconnected every 2 to 3 days is classed as normal. I have been with different isp in the past but at a different address and never has disconnections every 2 to 3 days.
chrispurvey
It's not normal, but it is a very low amount. I presumed it was dropping out more from your comments.
I can see you've got a support ticket open, I'd suggest running through our faults wizard at http://faults.plus.net and we'll take a closer look at that.
Alex2x
The fault wizard just keeps timing out. I got through to the last question on one try  asking my to select "my connection keeps dropping"  but there was no where to click next or ok so I had only two options click on my problem is resolved or return to plus net home page.
orbrey
It runs a line test at that point and I believe also checks your connection logs, but the test unfortunately failed. Having said that though the ticket did get raised and is sat with our faults team so they'll be back to you soon.
Alex2x
Do PlusNet offer Routers for sale I didn't take one when I joined, I'm beginning to think my problem amount to faulty routers
adamwalker
Fixes: 221
@Alex2x
Yes, we can provide you with a Technicolor TG582n for £40 plus £5.99 postage and packing or alternatively you can just pay £5.99 and take the router for free unless you were to leave within 12 months in which case we'd then want the £40.
Adam
 Adam Walker
Alex2x
That's sounds good how to I go about getting one.
