Can you turn on Interleaving Please
- Can you turn on Interleaving Please
- « Previous
- Next »
Re: Can you turn on Interleaving Please
12-05-2013 4:31 PM
Hello again just to let you know my connection has remained up for 4 days now, that's the longest I have been connected. So the problem was with my routers, The Technicolor Router is holding the connection fine and the SNR stays between 5.4 - 5.9. So I would like to say a big thank you to everyone that help me with this issue. I will reply to the raised ticket and thank them also.
Cheers Alex.
Uptime: 4 days, 0:45:57
DSL Type: ITU-T G.992.3
Bandwidth (Up/Down) [kbps/kbps]: 440 / 4,921
Data Transferred (Sent/Received) [MB/GB]: 355.35 / 1.99
Output Power (Up/Down) [dBm]: 12.7 / 0.0
Line Attenuation (Up/Down) [dB]: 32.8 / 54.5
SN Margin (Up/Down) [dB]: 22.3 / 5.4
Loss of Link (Remote): -
Error Seconds (Local/Remote): 413 / 0
FEC Errors (Up/Down): 532 / 163,465
CRC Errors (Up/Down): 11 / 590
HEC Errors (Up/Down): 7 / 3,197
Cheers Alex.
Message 31 of 36
(357 Views)
13-05-2013 1:42 PM
Great to hear, long may it continue
![Smiley Smiley](/html/@39650D28FE4EA73A5BA77CFD0A477003/images/emoticons/smiley.gif)
Message 32 of 36
(357 Views)
14-05-2013 5:46 PM
Is there anyway my profile can be increased. I was under the impression, though I maybe wrong, that if you remained connected for 3- 5 day the exchange would automatically adjust your profile. Mine hasn't moved since installing the new Router, and that was 6 days ago now.
Message 33 of 36
(357 Views)
15-05-2013 9:34 AM
Your profile is currently set correctly, is there anything making you think it's not?
Message 34 of 36
(357 Views)
15-05-2013 12:17 PM
I was expecting 5.5mb that what I used to get
Message 35 of 36
(357 Views)
15-05-2013 2:03 PM
Quote from: Alex2x Uptime: 4 days, 0:45:57
As your stats show you're currently syncing below 5.5Mb/s, are you connected into your test socket?
Message 36 of 36
(357 Views)
- « Previous
- Next »
