Can't access one website
Fixes: 383
Re: Can't access one website
@sweep2 What  sites are giving you problems?
sweep2
It’s an adult website
Fixes: 383
@sweep2  - Ah. In that case, could you reach it with your previous ISP?
sweep2
Yes no problem with BT
Fixes: 383
In that case - I'm confused. What happens when you try to reach it on PN?
sweep2
Blank white page. I can actually access the page though.
Fixes: 383
Very strange. Can you Private message me the site? You don't have Parental Control enabled do you?
Fixes: 383
I can get there, but I'm not with PN. You need someone who is to check/ As I said, you haven't got Plusnet Safeguard on, have you?
sweep2
No I haven’t
sweep2
Tried adding to never block list and I’ve turned off a few block opt that were ticked. But I’ve done this now about 4 times x as nd they keep coming back.
Fixes: 383
Sorry I can't help any more - as I said, I can get there, but I'm not with PN, and never had this issue, with any site, when I was, although I  never had Safeguard set.
LexLex2020
Fixes: 12
@sweep2 I know this seems a little simple but have you tried to switch off your router for maybe 5-ish minutes to generate a new IP address?
Could be a good start to find what the cause of the issue is.
Also have you tried opening the site in a private browser, or through another browser?
One last thing, are there any other websites being affected or just the one?
- Lex
Lex Keehner
sweep2
I’ll give it a go.
Similar site from the same stable also affected.
sweep2
I’ve been working in Poland all week not had time to try anything. I’ll try tomorrow
LexLex2020
Fixes: 12
No worries,
Let us know how it goes.
Lex Keehner
