Can I keep my static IP when moving from Premier to Fibre?
- Re: Can I keep my static IP when moving from Premi...
14-10-2011 3:37 PM
Well not necessarily the same IP, I'm not that attached to those particular numbers. But I want to stay static. Is that possible? If so, how do I go about requesting it?
A tortoise? What's that?
You know what a turtle is? Same thing.
Message 1 of 3
(790 Views)
2 REPLIES 2
Re: Can I keep my static IP when moving from Premier to Fibre?
14-10-2011 3:51 PM
Yes, you can keep the static IP. It should remain on the account throughout the change so keep the same one.
Message 2 of 3
(358 Views)
16-10-2011 8:55 AM
Mine has just been done and the static IP stayed, thanks PlusNet!
Dave
Dave
Message 3 of 3
(358 Views)
