Can I keep my static IP when moving from Premier to Fibre?
lorisarvendu
Well not necessarily the same IP,  I'm not that attached to those particular numbers. Grin  But I want to stay static. Is that possible?  If so, how do I go about requesting it?
A tortoise? What's that?
You know what a turtle is? Same thing.
2 REPLIES 2
orbrey
Re: Can I keep my static IP when moving from Premier to Fibre?
Yes, you can keep the static IP. It should remain on the account throughout the change so keep the same one.
Dave777
Mine has just been done and the static IP stayed, thanks PlusNet!
Dave
