Can I have a static IP address?
- Re: Can I have a static IP address?
11-01-2015 7:54 PM
Are PlusNet able to let me have a static/fixed IP address?
If so, how much does it cost and how do I get one!?
I'm no technical expert but it's part of setting up my CCTV camera which is connected to my router and I want to be able to look at my CCTV from the internet - I understand this is easier if your IP address doesn't keep changing.
Message 1 of 9
(1,423 Views)
8 REPLIES 8
11-01-2015 7:57 PM
it's available on certain accounts for a one off fee of £5
Quote Adding or removing a Static IP
If you'd like to add or remove a Static IP please raise a Ticket or call our Support Team on 0800 432 0200 or 0345 140 0200
Message 2 of 9
(926 Views)
11-01-2015 8:31 PM
I added a static IP to mine through the member centre - it was one of the options on the account.
Message 3 of 9
(926 Views)
11-01-2015 8:33 PM
i think that has since gone, I copied that from my static ip page in the member centre
Message 4 of 9
(926 Views)
11-01-2015 8:37 PM
The option to add a static ip to your account is available to action in the member centre, I have just done it (accidentally). It is under the Add ons tab and you click on apply now. BE CAREFUL though as there is no confirmation, once clicked, you have committed to a static ip which I think is wrong.
CS. Can this static ip be removed from my account please with no charge? I think it is wrong that one click commits you with no option to opt out of the transaction.
Mark
Mark
Message 5 of 9
(926 Views)
11-01-2015 8:38 PM
Ahh right - I did mine a couple of years ago - how time flies ......
Message 6 of 9
(926 Views)
12-01-2015 1:27 PM
Message 7 of 9
(926 Views)
12-01-2015 1:29 PM
Message 8 of 9
(926 Views)
12-01-2015 3:29 PM
Yes I had Tony, didn't want to clog the thread up. Thanks
Message 9 of 9
(926 Views)
