CSC Agents not answering the right question
- CSC Agents not answering the right question
Re: CSC Agents not answering the right question
28-11-2011 4:28 PM
The SNR you see on my line right now if jumping between 4 and 6dB. If I were to reset my line now, it would likely sync below the 2272kb/s needed for a 2Mb BRAS setting.
This is one of the same mistakes all the CSC staff are making on this ticket too.
3Mb FTTC
28-11-2011 4:33 PM
I've been liaising with one of our faults guys about this, talking about possibly getting an engineer out. If we do arrange that you'd need to make sure you're in the test socket when he comes, or he might try to point to internal wiring. Are you happy for us to pursue this for you?
Jojo
28-11-2011 4:43 PM
Please update my ticket, also, please try and copy/paste exactly the information given to BT so I can sing the same tune.
Also, they need to bring an excavator to be able to reach the two points where the line has been 'repaired' by previous BT engineers!
3Mb FTTC
28-11-2011 5:36 PM
An engineer's been booked now for between 8am-1pm on Friday.
Jojo
28-11-2011 7:06 PM
Speedtest done as requested. Image attached.
3Mb FTTC
29-11-2011 7:46 AM
3Mb FTTC
02-12-2011 1:01 PM
However, with it being a clear day with a light blue sky, as expected, all his results indicate there is no problem.
I can fault their training, as a part of our chit chat, it was clear they did not understand the difference between exchange contention and the adsl sync speed. Yes of course they both result in poor speed test results, and I think this is also a common problem I have seen in all CSC replies to my ticket by PlusNet.
Where do we go from here assuming you get the same status information from BTO?
3Mb FTTC
02-12-2011 5:33 PM
I've reviewed your fault today. The engineer notes suggest that the line was tested ok and all checks passed. As you say this could be down to the weather conditions.
I'd just like to confirm, have you tested your line with an alternative router? I've looked back through this thread and your ticket to see if there has been any confirmation of this previously but couldn't see anything. Apologies in advance if i missed it.
02-12-2011 5:58 PM
Yes, got your voicemail thanks.
In 2008, when I had the same problem, I did try a BT 2Wire router too, it had the same problem as the Netgear. I still have the 2Wire router.
If you feel one of the Thomson routers PN uses as standard would be better to use, as it is supported by routerstats, and it is a device PN 'know and love', please go ahead and send me one on loan to investigate this problem.
See attached for how routerstats saw my line quality at the time when the SFI engineer had just finished his testing. So his equipment apparently could not see this varying SNR as shown after 11:39. We can see that he disconnected the phone line at 11:13. So unless the noise started immediately after he stopped testing, we could assume the noises we see after 11:39 was also present while his test equipment was connected from 11:13 to 11:39 and so should have seen the same varying levels of noise too. Yes understood this is a part of why you want to try a different router.
But still his test equipment gave a little coloumn of green symbols and this meant the 'line was good'.
3Mb FTTC
02-12-2011 6:02 PM
3Mb FTTC
04-12-2011 11:20 PM
On Sunday, I thought I would plug the 2Wire router in and see what it thought, before I did, I looked at the current stats and they looked noise free.
The 1st image shows the SNR up until about midday. Looks clear.
Now at nearly 11PM, the 2nd image shows things are on the downward trend again.
3Mb FTTC
05-12-2011 8:17 AM
3Mb FTTC
05-12-2011 5:42 PM
3Mb FTTC
06-12-2011 7:18 AM
3Mb FTTC
06-12-2011 4:23 PM
