Broadband speed
racedemon
Re: Broadband speed
How much is the P+P for a new router then?
racedemon
Re: Broadband speed
The downsteam speed has stayed the same.
MatthewWheeler
Fixes: 480
Re: Broadband speed
The postage and packaging would be £6.99
With regards to the DLM query your profile is currently "WBC 4M - 9M No delay (INP 0) 6dB Downstream, UC No delay (INP 0) 6dB Upstream (ADSL2+)" so I've actioned another reset which has increased your sync speed.
Let us know how you get on.
 Matthew Wheeler
racedemon
Re: Broadband speed
  Link Information
Uptime: 0 days, 1:09:23
DSL Type: ITU-T G.992.5
Bandwidth (Up/Down) [kbps/kbps]: 446 / 15,101
Data Transferred (Sent/Received) [MB/MB]: 6.41 / 37.77
Output Power (Up/Down) [dBm]: 12.6 / 0.0
Line Attenuation (Up/Down) [dB]: 16.7 / 28.5
SN Margin (Up/Down) [dB]: 30.4 / 6.0
Loss of Link (Remote): -
Error Seconds (Local/Remote): 3,229 / 0
FEC Errors (Up/Down): 569 / 29,196,773
CRC Errors (Up/Down): 7 / 242,672
HEC Errors (Up/Down): 1 / 903,284
send me a new router.
Fixes: 1,601
Re: Broadband speed
Just done that for you now, it should arrive within the next 3 to 5 working days.
Fixes: 161
Re: Broadband speed
@Gandalf,
Is that US capped?
HarryB
Fixes: 256
Re: Broadband speed
That upstream is actually uncapped.
 Harry Beesley
Fixes: 161
Re: Broadband speed
OK ... so why is it so slow and at such a high SNRM?
Chris
Legend
Fixes: 169
Re: Broadband speed
The line is definitely uncapped, checking the asset directly showed this. However I believe that on a previous DLM change the upstream was set to 448 incorrectly. I've put a new one through and it's back to a 1200 sync on the upstream.
