Broadband not working
samx20x
My broadband is not working and there are no service issues in my area
12 REPLIES 12
Fixes: 374
Re: Broadband not working
@samx20x Are you really on ADSL broadband? In what way is it 'not working'?
samx20x
I think I've posted in the wrong forum I'm fibre. Sorry
Fixes: 374
OK - I'm still mystified by what you mean by 'not working', but try and follow the below text - it may give other Community members a chance to suggest the next step(s)
For Community members to be able to help, information from these two sites, as screenshots:-
BT Broadband(obscuring your phone number) and BTW Performance Tester - Over a wired (ethernet) connection if at all possible, please report the 'ADDITIONAL DIAGNOSTICS', and sight of the broadband connection status from your Hub would be a good starting point.
For the Hub One -
For the Hub Two -
If phone test is OK then take the front off your telephone master socket, you may need to remove two screws. In behind you will find the test socket. Plug a filter in here and connect that to your hub. If it’s still dropping out then report a fault at https://faults.plus.net.
Mustrum
Fixes: 81
Your post will get moved, don't worry about that, and individual line issues will not show up in service issues.
So how about some basic info, is your phone line working, which router and what lights, have you reported a fault?
PS, ah @jab1  beat me to it!
samx20x
My hub is flashing orange then green then orange. Internet is not working
Fixes: 374
@Mustrum See my post above. 😁
samx20x
I dont use the phone line so I wouldn't know if I can make calls. I should have a blue light but I'm getting a blue light for about 10 seconds then flashing orange and green.
Mustrum
Fixes: 81
@jab1  and my PS 😀
Good luck on this one 😎
Fixes: 472
Moderators Note
This topic has been moved from ADSL Broadband to Fibre
Fixes: 374
Try following my post earlier. A basic phone is an essential tool for fault-finding on an ADSL/FTTC connection
samx20x
I have reported it and its come back with a fault on my line. Thank you
adamwalker
Fixes: 223
Hi there, I've just checked and can see we've had an update back from our suppliers asking us to arrange an engineer visit with you. I've added an update to the ticket here for you: https://www.plus.net/wizard/?p=view_question&id=224593197
Please have a look when you can and let us know back on here when you've responded.
 Adam Walker
