Broadband issues
Ragismiks
Re: Broadband issues
Okay no probs will do.
Thanks for all the help so far 👍👍
Ragismiks
Screenshot_20240716_094735_Samsung Internet.jpgScreenshot_20240716_094735_Samsung Internet.jpgScreenshot_20240716_094724_Samsung Internet.jpgScreenshot_20240716_094724_Samsung Internet.jpgScreenshot_20240716_094444_Samsung Internet.jpgScreenshot_20240716_094444_Samsung Internet.jpgScreenshot_20240716_094207_Samsung Internet.jpgScreenshot_20240716_094207_Samsung Internet.jpgScreenshot_20240716_094156_Samsung Internet.jpgScreenshot_20240716_094156_Samsung Internet.jpg
Ragismiks
Wifi that bad this morning I can't even access the broadband speed site.
Turned wifi off works fine.
Netflix won't run, says connection problem.🤦‍♂️
Fixes: 378
'@Ragismiks That availability checker result does not make sense - you are on an FTTP priority exchange and yet it is 'not available' ?Huh
Are you saying you are now using a wired connection?
@MisterW  / @Dan_the_Van  - any thoughts?
Fixes: 577
@jab1 perfectly ok. It means that the exchange area is FTTP priority. It doesnt mean that FTTP is available in all locations in that area. If its available in the location then ONLY FTTP can be ordered, if its not available SoGEA can be ordered , as in this case.
Fixes: 378
Thanks @MisterW - should have realised that! Embarrassed Noting @markhawkin  's comments above, looks like whoever planned MK was totally incompetent.
Fixes: 577
Probably applies to MK in its entirety, not just the network infrastructure🤣
Fixes: 378
True. 😂
Fixes: 475
What works fine? Do you get the full contracted speed?
Ragismiks
I don't have a option to use wired atm.
Is it best for me to find a wired connection?
Fixes: 378
If you turned Wi-Fi off, how are you connecting?
Do you mean you are only using mobile devices/Macbooks &c?
Ragismiks
I couldn't get the speed test done with wifi connected as it won't load up, broadband is unusable this morning.. I can't open that BP speed test.
Fixes: 378
Going back to your 'Technical Log' in post #17, something is really hammering your connection - 1.9GB up/2.3GB down in 6hours?
Ragismiks
We got ring doorbell, cctv and probably 4 kids watching the netflix or on their tech before the school, that could be the use of it.
It's just bad even at nights, I work nights and around 2am signal was barely existing, had to use my mobile as a hotspot again to work
Fixes: 378
OK. You have a very poor 'connected' speed, but apparently, so does a lot of  MK, due to the way it was built - badly. Having said that, the fact that your DSL connection had only been up for ~6 hours points to a fault in the OpenReach infrastructure.
I'm out for a couple of hours now, but is it possible to export your Event Log - see picture below - and attach it to a post?
