Broadband is terribly slow
- Re: Broadband is terribly slow
- « Previous
- Next »
08-02-2014 12:43 PM
Two things
The BT profile hasn't changed yet
Much more important
Raise a ticket to move to 21CN this should give you a significant speed increase and also increase the upload speed - there is no cost for this
It will also fix the BT IP profile problem as on 21CN it changes instantly
Much more important
Message 31 of 38
(564 Views)
08-02-2014 12:45 PM
Understood, is there a specific way to raise a ticket for this reason?
Message 32 of 38
(564 Views)
08-02-2014 12:50 PM
Not really but this might be the best https://www.plus.net/wizard/?p=wizard&page=22934&wizard_id=38
Message 33 of 38
(564 Views)
08-02-2014 12:59 PM
Thanks a bunch, I've done what you suggested and I've opened a ticket. However the response time is over 24 hours, so I'm going to try ring Plusnet and see if they can deal with it over the phone.
Thank you to everyone who helped.
Message 34 of 38
(564 Views)
08-02-2014 1:00 PM
It won't happen until after Monday anyway as it needs BT to go into the exchange and physically move your connection
Message 35 of 38
(564 Views)
08-02-2014 2:39 PM
I see, in that case is it possible to somehow force the update of the BT IP Profile? I mean can you guys do it or can I ring up BT?
Message 36 of 38
(564 Views)
08-02-2014 2:42 PM
It has to be done by Plusnet and that means staff not moderators
Message 37 of 38
(564 Views)
10-02-2014 10:51 AM
An order has been placed and I've replied to Ticket: 81017173.
Message 38 of 38
(564 Views)
- « Previous
- Next »
