Broadband fault
SteveR
Broadband fault
Hi
My broadband has been flaky since the weekend but is now nearly non existent. I am on FTTC with a fixed IP address. DSL stays up all the time. I swapped modem and router but the results are still the same. Here is my Thinkbroadband Quality monitor.
https://www.thinkbroadband.com/broadband/monitoring/quality/share/fb880653a7d46761131291fa4c3f57af40dea4a0
Regards
SteveR
5 REPLIES 5
Fixes: 385
Re: Broadband fault
@SteveR Use the faults bot to report your issue:https://www.plus.net/help/report-a-problem/
Fixes: 249
Re: Broadband fault
@SteveR
What is your location?
SteveR
Re: Broadband fault
Many thanks to whoever got it fixed my internet is back up and the graph looks much more healthy now.
Regards
SteveR
Fixes: 249
Re: Broadband fault
Location?
North Manchester?
Localised issue there resolved 2am today.
SteveR
Re: Broadband fault
Yes. north Manchester.
