Broadband Very Slow - DLM Reset Request
digit101
Hi, My fttc has become very slow. The upload has been capped at 0.8mbit. Please I have DLM reset / uncap. The line is now stable but the cap has not lifted.  It was caused by the modem cable being unplugged several times.
Thanks in advance.
4 REPLIES 4
Fixes: 463
Re: Broadband Very Slow - DLM Reset Request
@digit101
Use the text bot and report a fault, it will probably be quicker. : See  https://www.plus.net/help/report-a-problem/
digit101
Hi, can a DLM reset no longer be done by a moderator? It used to be possible a few years ago?
Fixes: 353
@digit101 No - has to be done via Plusnet. I have never known mods (who are not PN staff, btw), to be able to access the PN network.
lahbrannan1
Fixes: 4
Hi @digit101
Do you still need a DLM reset performing?
If so, please let me know and I'll reach out to see if it is possible.
Lee
Lee Brannan
