Multiple locations
cjberry004
Multiple locations
If you have a second home can u have a router sent to that address on same account?
4 REPLIES 4
Fixes: 387
Re: Multiple locations
No - each property will need its own account.
Fixes: 251
That’s an ambiguous question in respect of delivery of a router.  For the supply of service to a second property, each will be a separate account as advised by @jab1.  Do make sure that the second account references the first as being the referrer, to give the first a referrer’s bonus.
If the second property is not always occupied then by arrangement it would be possible to have the router delivered to the address of the first property.
Similarly if supply is only required at the first property but there’s going to be no one there to receive the router (for example as in a house move), by arrangement it can be despatch to an alternative address.
Fixes: 387
@Townman The way I  read the original post was that @cjberry004 expected to be able to use their home service at the second property, just by having a router there.
Fixes: 251
@jab1
Indeed the question was open to several interpretations, from the simple delivery of a router to an alternative address, through to two services on one account, down to can one plug a router in anywhere and expect that it will work like MiFi does.  We have seen many oddly phrased questions leading to an answer for a different question, to that intended by the OP.
Together, all bases of this potential ambiguity have been covered! Cheesy
