Broadband Service ID query
RCully
I want to carry out a speed test for my fibre broadband, but can't do the full additional diagnostic test, as this requires a broadband service ID.
I used to be able to put in my phone number, but it looks like you can't do this anymore.
Where can i find my broadband service ID?
17 REPLIES 17
Fixes: 384
Re: Broadband Service ID query
RCully
Thanks for the try but this site only gives me something called a UPRN (I couldn't find anything else it gave including a Broadband Service ID)
Hopefully someone from Plusnet can provide this for me.
Roy
Fixes: 384
@RCully OK - I'm not on FTTP, so see a different set of options to you.
RCully
Apologies John, I'm not on FTTP either, the service is FTTC and I have included a screenshot of what is being requested.  If I select the landline option, it takes the number, goes to the next green and just sits there with four circles going around but nothing else happens.
I assume you see the same as the screenshot(?).  If you do, give it a try and please let me know if it works for you
Roy
Fixes: 384
OK Roy, thanks for the clarification. That is strange - I am exactly the same as you, but if i enter my phone number (including the exchange code, with no spaces), it then attempts to run the further diagnostics, but fails to complete - with a spurious error message, claiming the system is 'busy' two times out of 3 (on average).
RCully
Mmmm.
I would normally suggest that this is a system problem but I've had it several times before so not sure if it just doesn't work full stop.
hopefully someone will ride to the rescue re the service ID
cheers  Roy
Fixes: 384
Result when I try the further diagnostics, as you are:
Screenshot 2023-02-22 at 18-47-10 BTW Performance Tester.pngEDIT: I assume you are selecting the 'Telephone number box (far right)  and entering your phone number - I suspect if you try entering your phone number with the BBEU option selected, it won't work.
Browni
Aspiring Hero
Fixes: 61
Working fine here using my telephone number on a BT connection.
The advanced diagnostics page does take a little time to appear though.
BT Speedtest 22/02/23BT Speedtest 22/02/23
Fixes: 384
I suspect my 'issue' is possibly down to using a non-BT Consumer ISP, I very rarely had the issue before I left PN.
RCully
John,  Yep, I'm selecting the phone number box.
I've just tried yet again and the 4 circles just kept spinning until I gave up after about half an hour.
Browni
Aspiring Hero
Fixes: 61
I've just timed getting into the advanced diagnostics page - 43 seconds (felt a lot longer!)
I don't know why it takes so long as it isn't running another speed test.
Fixes: 384
Any chance you could do a screen capture and post it on here - I've never seen 'green circles'?
Fixes: 384
As you see from my screenshot, the advanced diagnostic page loads, but the response is, effectively 'oops, something went wrong' . I am a bad example, though - my connection doesn't go near the BT 'backbone' as Zen have their own network.
JayG
Fixes: 6
Just tried the further diagnostic test on my Plusnet FTTC connection using my telephone number - got the 4 spinning green circles for 20 seconds, followed by a popup window advising that the page was not responding. Clicked 'wait' and the test successfully completed almost immediately.
The previous version of the BTW tester was notoriously flaky - this one also needs to be caught in the right mood apparently. 🤔
