Broadband Router (SAGEMCOM 2704) Port Fowarding for CCTV doing weird things!
TSS24
Hi all,
I would welcome some technical support frm the "chief geeks" out there.
Simply I need to Port forward 80 and 50100 (TCP and UDP) on my router to my CCTV DVR system. I have set this up on the Router SAGEMCOM 2704 no problem.
I have also got a Dynamic DNS service "PowerDDNS" up and running to keep the DHCP ISP IP-fixed to a DNS name.
I then use http://www.yougetsignal.com/tools/open-ports/ to check the PORTS are "Open" and they come back CLOSED each time.!!
But then  Port Checker it works suddenly, at random times!!
I have fixed the Internal LAN Ip-dress of the CCTV DVR to 192.168.1.1and everything WORKS OK from the LAN. Ie forma PC on the internal LAN.
Problem is when I use SMARTEYESPRO CCTV viewer on my Iphone, AGAIN it is 'hit and miss' if it works over 3G/4G.
I have checked the PlusNet On-line Firewall via my account switched off and only got Norton Security doing usual stuff (anti virus, Malware, windows firewall control etc..)
Please, please, please help?? I just want it to work via my mobile over 3G/4G, so I can use CCTV when away from home Sad
2 REPLIES 2
Anotherone
Champion
Fixes: 21
Re: Broadband Router (SAGEMCOM 2704) Port Fowarding for CCTV doing weird things!
See https://community.plus.net/t5/Tech-Help-Software-Hardware-etc/CCTV-Remote-Viewing/m-p/1344802#M72713 and some earlier posts in the thread, as well as a number of posts about 2704n port-forwarding on the Hardware board.
Mav
Fixes: 515
Moderator's note by Mike (Mav)
Thread locked in favour of the link above.
Forum Moderator and Customer
