Broadband Getting Slower
stephenheron
I first moved into my property a few years ago and looking at back at older speed tests I did I was getting around 50 - 55 Mbps.
However I think it has been getting a bit slower over that time, I can't quite pinpoint the date but doing a speedtest now I am looking at around 40 - 40 Mbps,
I have attached my BT Wholesale checker results.
I am just wondering if this is something I should get in touch with Plusnet about? Or am I just a bit unlucky?! I think I am a bit away from being about to get FTTP so it's a tad frustrating.
Thanks,
Stephen
24 REPLIES 24
stephenheron
Re: Broadband Getting Slower
I thought I would check the BT Wholesale Speedchecker as well to see what it was saying, but if I try to do the advanced test I just get an error:
Fixes: 374
@stephenheron You could be suffering from a couple of things - or not. If you can post the answers to the below (ignoring the two tests you've done, Community members may be able to advise:
BTW Performance Tester - Over a wired (Ethernet) connection if at all possible, please report the 'ADDITIONAL DIAGNOSTICS'. This test is recommended to be performed with only one device connected.
For the Hub One -
For the Hub Two -
stephenheron
@jab1
I think my original posts contain the details from the BT Availability Checker and the BTW Performance Testers, my apologies if I have done something wrong, if you could point me in the right direction then that would be great.
From your helpful instructions I have pulled the details from the Hub.
I unfortunately don't have a phone so I can't do the 'Quiet Line Test'
Thanks,
Stephen
Fixes: 374
@stephenheron I did say 'ignoring the two tests you have already done' 😉 - the instructions I posted are a direct copy and paste  of a standard 'help sheet'.
From your Technical log page, I am suspecting xDSL drops caused by Openreach equipment issues  - to confirm, can you please export the complete log and post the result.
stephenheron
@jab1 Whoops, sorry! That teaches me to read more carefully! 😅
Sorry to be a pain but how do I export the complete log?
Fixes: 374
No problem, Stephen - it happens to us all. 😀
To export the complete log, try navigating to the page below and clicking the pink 'Export' box. This should produce a file which you can attach to your reply. If it doesn't, my apologies and I will seek guidance.I have never used the PN Hubs, merely worked from help I have received from others.
Fixes: 145
@jab1
He's got a Hub One
@stephenheron
Navigate from the home page to >Troubleshooting >Event log. Category WAN would be best to start with, copy/paste a couple of pages to a text file
HTH
Fixes: 374
Ooops - must read the full help desk, @Dan_the_Van Embarrassed
Fixes: 145
No worries, I've had some fun today 🙄
Time for dinner
Dan.
Fixes: 374
Yep - I saw. 😉
stephenheron
Cheers @jab1 and @Dan_the_Van
Wan Logs are attached.
Quite useful actually as I can see that back in April I was syncing at "48941Kbps", which is around what I remember it being at for ages, then since then it's dropped down to what I am seeing more recently, it's not a massive drop looking at it! Just a bit strange as I haven't changed anything on my end!
Fixes: 374
Thanks for that, @stephenheron - it proves what I suspected - there is something going on which has caused your downstream SNR to rise, consequently depressing your speed. As you don't have a phone to test for noise, unfortunately, I suggest as a first step that you report a broadband fault using this link: https://www.plus.net/help/report-a-problem/broadband/
Let us know the result.
Fixes: 145
 As @jab1 says, stuff doesn't look right.
Did you power cycle you Hub around 3:30 pm? as it looks to have rebooted then?
15:34:57, 15 Nov. ( 36.230000) WAN Auto-​sensing running.
15:32:21, 15 Nov. (5425430.870000) WAN operating mode is VDSL
At 15:34:57 the Hub was switch on only for 36 seconds ( 36.230000)
If not can you look at category "All" around the above time 15:32 and copy/paste the event text?
stephenheron
@jab1 and @Dan_the_Van Cheers for the help guys!
@Dan_the_Van we actually had a tiny power cut at that time, just for a second, which is what prompted the investigation of what was going on, as I logged into the router to make sure everything came back fine.
So I tried the help link you gave me @jab1 where I sent a text message, and they ran a test but it came back that everything was Ok, they then asked todo a refresh which seemed to do nothing as it is just syncing exactly the same.
