Broadband Dropouts
MichaelBendikas
Broadband Dropouts
At the times 11-2 i receive about 2-10 dropouts of the internet, i don't know whats going on. Has anyone experienced this before?
Re: Broadband Dropouts
Below is a graph of your connection:
<img src="http://ccgi.psmith12.plus.com/visradius/generated/image13723242973755.png"/>
As you stated your line is dropping at similar times daily, is there anything in your house that is turned on/off at these times?
MichaelBendikas
Nope we are normally all asleep during this time. However i do have a home plug extending the connection upstairs to a computer which is turned off at night. However this plug is constantly turned on and off during the day so it shouldn't make a difference. The plug that is connected to the main router downstairs is never turned off.
MichaelBendikas
Also this happens occasionally
When i should be getting speeds of 3.5mb/s+
houlton23
Dead weird how it always drops in the middle of the night :/
Post a screeny of your router stats?
Tbh I've always thought your line syncs a bit low, maybe there's something going on here...
MichaelBendikas
And this one i don't know what happened
houlton23
The last one is when the number actually goes negative, but the router is too stupid to display it properly...
Run in command prompt: "ping bbc.co.uk" and post the results?
MichaelBendikas
MichaelBendikas
From that ^ To this
Internet has sorted itself out now but it'll do it again at some-point
houlton23
Has it dropped at all in between those tests?
MichaelBendikas
Not those, instead of dropping sometimes it just makes my speed slow, it doesn't drop during this slowness
houlton23
Alright, you might be getting bursts of errors, I've forgotten what router you have?
MichaelBendikas
Netgear DG834G
houlton23
Okay, need to get some error stats but I can't be bothered to explain how to do it :L
I'll come round Saturday and have a look, wanna see iOS 7 anyway!
MichaelBendikas
BusyBox v0.61.pre (2007.04.16-10:12+0000) Built-in shell (ash)
Enter 'help' for a list of built-in commands.
# cat /proc/avalanche/avsar_modem_stats
AR7 DSL Modem Statistics:
[DSL Modem Stats]
        US Connection Rate:    1011    DS Connection Rate:    6097
        DS Line Attenuation:    42      DS Margin:              8
        US Line Attenuation:    24      US Margin:              6
        US Payload :            4185180912      DS Payload:            99437032
0
        US Superframe Cnt :    13568801        DS Superframe Cnt:      13568801
        US Transmit Power :    0      DS Transmit Power:      0
        LOS errors:            0      SEF errors:            0
        Errored Seconds:        8289    Severely Err Secs:      3958
        Frame mode:            0      Max Frame mode:        0
        Trained Path:          1      US Peak Cell Rate:      2384
        Trained Mode:          8      Selected Mode:          1
        ATUC Vendor Code:      4946544E        ATUC Revision:  2
        Hybrid Selected:        3      Trellis:                1
        Showtime Count:        4      DS Max Attainable Bit Rate: 6556 kbps
        BitSwap:                1      US Max Attainable Bit Rate: 1012000 bps
        Annex:                  AnxA    psd_mask_qualifier: 0x0000
        ATUC ghsVid:  b5 00 49 46 54 4e 71 c8
        T1413Vid: 00 00        T1413Rev: 00            VendorRev: 00
        ATUR ghsVid:  b5 00 54 53 54 43 00 00
        [Upstream (TX) Interleave path]
        CRC:    0      FEC:    0      NCD:    0
        LCD:    0      HEC:    0
        [Downstream (RX) Interleave path]
        LCD:    0      HEC:    0
        [Upstream (TX) Fast path]
        CRC:    9      FEC:    0      NCD:    0
        LCD:    0      HEC:    0
        [Downstream (RX) Fast path]
        CRC:    169463  FEC:    0      NCD:    0
        LCD:    0      HEC:    0
[ATM Stats]
        [Upstream/TX]
        Good Cell Cnt:  87191269
        Idle Cell Cnt:  463335229
        [Downstream/RX)]
        Good Cell Cnt:  468108475
        Idle Cell Cnt:  2849081295
        Bad Hec Cell Cnt:      285642
        Overflow Dropped Cell Cnt:      0
[SAR AAL5 Stats]
        Tx PDU's:      17167785
        Rx PDU's:      22910788
        Tx Total Bytes: 3560489045
        Rx Total Bytes: 2522439933
        Tx Total Error Counts:  0
        Rx Total Error Counts:  215963
[OAM Stats]
        Near End F5 Loop Back Count:    0
        Near End F4 Loop Back Count:    0
        Far End F5 Loop Back Count:    0
        Far End F4 Loop Back Count:    0
        SAR OAM Ping Response Drop Count=0
