Broadband Dropouts
- Broadband Dropouts
Broadband Dropouts
26-06-2013 11:35 PM
Re: Broadband Dropouts
27-06-2013 10:13 AM
Below is a graph of your connection:
<img src="http://ccgi.psmith12.plus.com/visradius/generated/image13723242973755.png"/>
As you stated your line is dropping at similar times daily, is there anything in your house that is turned on/off at these times?
27-06-2013 6:32 PM
27-06-2013 9:09 PM
27-06-2013 9:41 PM
Post a screeny of your router stats?
Tbh I've always thought your line syncs a bit low, maybe there's something going on here...
27-06-2013 9:49 PM
And this one i don't know what happened
27-06-2013 9:52 PM
Run in command prompt: "ping bbc.co.uk" and post the results?
27-06-2013 9:55 PM
27-06-2013 9:57 PM
27-06-2013 9:58 PM
27-06-2013 10:01 PM
27-06-2013 10:06 PM
27-06-2013 10:11 PM
27-06-2013 10:21 PM
I'll come round Saturday and have a look, wanna see iOS 7 anyway!
05-07-2013 5:31 PM
BusyBox v0.61.pre (2007.04.16-10:12+0000) Built-in shell (ash)
Enter 'help' for a list of built-in commands.
# cat /proc/avalanche/avsar_modem_stats
AR7 DSL Modem Statistics:
[DSL Modem Stats]
US Connection Rate: 1011 DS Connection Rate: 6097
DS Line Attenuation: 42 DS Margin: 8
US Line Attenuation: 24 US Margin: 6
US Payload : 4185180912 DS Payload: 99437032
0
US Superframe Cnt : 13568801 DS Superframe Cnt: 13568801
US Transmit Power : 0 DS Transmit Power: 0
LOS errors: 0 SEF errors: 0
Errored Seconds: 8289 Severely Err Secs: 3958
Frame mode: 0 Max Frame mode: 0
Trained Path: 1 US Peak Cell Rate: 2384
Trained Mode: 8 Selected Mode: 1
ATUC Vendor Code: 4946544E ATUC Revision: 2
Hybrid Selected: 3 Trellis: 1
Showtime Count: 4 DS Max Attainable Bit Rate: 6556 kbps
BitSwap: 1 US Max Attainable Bit Rate: 1012000 bps
Annex: AnxA psd_mask_qualifier: 0x0000
ATUC ghsVid: b5 00 49 46 54 4e 71 c8
T1413Vid: 00 00 T1413Rev: 00 VendorRev: 00
ATUR ghsVid: b5 00 54 53 54 43 00 00
[Upstream (TX) Interleave path]
CRC: 0 FEC: 0 NCD: 0
LCD: 0 HEC: 0
[Downstream (RX) Interleave path]
LCD: 0 HEC: 0
[Upstream (TX) Fast path]
CRC: 9 FEC: 0 NCD: 0
LCD: 0 HEC: 0
[Downstream (RX) Fast path]
CRC: 169463 FEC: 0 NCD: 0
LCD: 0 HEC: 0
[ATM Stats]
[Upstream/TX]
Good Cell Cnt: 87191269
Idle Cell Cnt: 463335229
[Downstream/RX)]
Good Cell Cnt: 468108475
Idle Cell Cnt: 2849081295
Bad Hec Cell Cnt: 285642
Overflow Dropped Cell Cnt: 0
[SAR AAL5 Stats]
Tx PDU's: 17167785
Rx PDU's: 22910788
Tx Total Bytes: 3560489045
Rx Total Bytes: 2522439933
Tx Total Error Counts: 0
Rx Total Error Counts: 215963
[OAM Stats]
Near End F5 Loop Back Count: 0
Near End F4 Loop Back Count: 0
Far End F5 Loop Back Count: 0
Far End F4 Loop Back Count: 0
SAR OAM Ping Response Drop Count=0
