Best Ethernet cable to purchase for PLUSNET Sagemcom 2704N ?
- Re: Best Ethernet cable to purchase for PLUSNET Sa...
19-04-2020 9:08 AM
i have just purchased a new all-in one acer computer.
i want to optimise the speed of my broadband connection. i.e. faster than WIFI
it's all a little overwhelming on cable monkey.co.uk re: the different types of cables available.
any assistance or guidance for me would be appreciated re: the cable specifications that i should be purchasing ?
i have an Aspire C24.
the type of plus-net router i have: Sagemcom router 2704N PLUSNET
really appreciate the assistance in advance,
many thanks plusnet
Re: Best Ethernet cable to purchase for PLUSNET Sagemcom 2704N ?
19-04-2020 9:18 AM
Welcome to the forums, @domsood . Did you not get an Ethernet cable with the router? If you did, use that. If you didn't, come back and we can have a look, although almost any cable from a reputable supplier should be OK.
19-04-2020 9:42 AM
The Hub Zero only has 100 Mbps LAN ports so any cable will do. To future proof the cable at a reaonable price go for Cat 5E.
19-04-2020 9:53 AM
run-IT-direct are a reputable reliable source.
Zen FTTC 40/10 + Digital Voice FRITZ!Box 7530
BT technician (Retired)
19-04-2020 11:06 AM
thankyou so much
19-04-2020 11:06 AM
thankyou so much appreciate it alot
