Being DDoSed
- Re: Being DDoSed
Being DDoSed
21-08-2013 1:15 AM
Hello,
I was contacted on Skype by someone who claims himself as a hacker and after being called many names, I discovered my connection dropped. Who was it? Him.
I am 95% sure I was DDoSed as my 70mb/s down speed dropped to 20 and my up speed was basically 0.
He stopped, called me many more names and threatens to continue dosing me because of my 'misleading online-games alias.'
I am not sure what to do now, suggestions?
(He uses a VPN, his real ip is masked.)
Message 1 of 8
(3,308 Views)
7 REPLIES 7
Re: Being DDoSed
21-08-2013 1:24 AM
I don't think there's much you can do other than block and ignore him, unless plusnet are able to mitigate DDoS attacks for you. I doubt it unless you're on a business connection.
Message 2 of 8
(795 Views)
Re: Being DDoSed
21-08-2013 1:33 AM
One question I'd like to ask is, do you have a misleading online-games alias?
That's RPM to you!!
Message 3 of 8
(795 Views)
Re: Being DDoSed
21-08-2013 1:38 AM
It's Ult1m4t3H4ck3r, i used to mod games. I've had that for a few years and never had any problems with it, except the occasional "why that name?"
Message 4 of 8
(795 Views)
Re: Being DDoSed
27-08-2013 8:46 AM
Cool story bro!
Message 5 of 8
(795 Views)
Re: Being DDoSed
27-08-2013 10:07 AM
If you can track the IP address the DOS is coming from (assuming it's just 1 and his) then you can use an IP lookup site and report him to his ISP, there should be an abuse contact address for them.
Message 6 of 8
(795 Views)
Re: Being DDoSed
27-08-2013 10:17 AM
Quote from: tonytoon
I'm sure if you contact his VPN provider, they will take action.
May help to copy any report from your routers log file and send that as evidence.
Message 7 of 8
(795 Views)
Re: Being DDoSed
27-08-2013 11:44 AM
Quick question, does the plusenet firewall (at plusnets end not a software firewall) allow for such things to be blocked?
Message 8 of 8
(795 Views)
