Bad Latency
- Re: Bad Latency
Bad Latency
12-06-2011 7:00 PM
I have been having very bad ping times since Friday afternoon, i have reported it and await a call back but as i play the xbox it is very frustrating. My ping times from around 11.30pm until late at night fluctuate between 200ms to 700ms yet early morning it is constant around 40ms. There is a drop in my speed but my line is syncing at the correct profile speeds. The first line tests by plusnet 1st line support show no fault but it is still under investigation by the faults team. I think and have said this is conjestion but i joined plusnet as gaming was supposed to be a priority yet xbox for me is unplayable!!
Message 1 of 8
(1,194 Views)
7 REPLIES 7
Re: Bad Latency
13-06-2011 4:30 PM
HI dazco,
It all depends where you are pinging to. A lot of sites aren't set up to prioritise ping requests. Can you supply as much information as possible, as your OP is not a lot to go on.
Jojo
Jojo
Message 2 of 8
(707 Views)
Re: Bad Latency
13-06-2011 4:51 PM
Having monitored my line since the issue began it is clear i am suffering conjestion, all day today my latency has been 40ms constant yet as soon as the kids have come home etc since 4pm my latency has gone through the roof again. I am still waiting for tech support to ring me back it has been almost 72 hours since i raised the ticket!!
My line sync is fine but my download speeds also drop when the latency rises, it peaks in an evening to around 700ms
I have pinged many sites dsl reports, google, bbc and more
Message 3 of 8
(707 Views)
Re: Bad Latency
13-06-2011 5:32 PM
Hi dazco,
The first thing I would notice from your post is that this happens when your children come home. If they are using computers for any bandwidth intensive activity you will see an effect on your computers performance; as well as the fact that it is the network's busiest time.
Jojo
Jojo
Message 4 of 8
(707 Views)
Re: Bad Latency
13-06-2011 5:38 PM
Sorry i meant when the kids came out from school not my kids. It is during peak times iam suffering which i know indicated conjestion at the exchange so Plusnet need to add some more at Dawley exchange Telford otherwise i will be moving ISP very soon as it has already been 72 hours since i raised a ticket and have been unable to play the xbox in an evening since Friday !!!
Message 5 of 8
(707 Views)
Re: Bad Latency
13-06-2011 7:01 PM
When you've time have a look at this page, it may help to confirm if it is or isn't congestion at your BT exchange.
Message 6 of 8
(707 Views)
Re: Bad Latency
14-06-2011 7:28 AM
Last night at around 9pm was really bad latency was over 1200ms and download speed was under 1mb !!! yet in the morning my latency was 40ms and 6.5 mb download it is definatley peak period slow downs iam seeing but after 72 hours i have still not had a call back from tech support. It is nearly 5 days that i have not been able to use my xbox in an evening and as gaming was the reason i came to plusnet iam far from happy
Type Interleave Path
Status SHOWTIME
Downstream Upstream
Data rate(Kbps) 8128Kb 448Kb
Noise Margin 9 25
Output power(dBm) 123 199
Attenuation(dB) 35 21
attached a screen shot of some traceroutes at 8.37pm last night. Non peak times my connection and latency is fine but from 4pm and the rest of the night my latency goes through the roof and my speed drops but not my line profile. Highest ping i have had is 1400ms last night
Status SHOWTIME
Downstream Upstream
Noise Margin 9 25
Message 7 of 8
(707 Views)
Re: Bad Latency
14-06-2011 10:11 AM
Hi dazco,
From that screenshot I can see you're connected wirelessly. Can you run some with a wired connection.
Jojo
Jojo
Message 8 of 8
(707 Views)
