Low speed at the moment?
- Low speed at the moment?
03-02-2011 9:41 AM
Today 09:35 1233 kbps (154kB/s) 366 kbps (45.8kB/s) Share
Today 09:30 1717 kbps (215kB/s) 365 kbps (45.6kB/s) Share
Today 09:27 1626 kbps (203kB/s) 372 kbps (46.5kB/s)
Same thing happened last night too.
Uptime: 0 days, 6:06:38
DSL Type: G.992.5 annex A
Maximum Bandwidth (Up/Down) [kbps/kbps]: 1,020 / 15,776
Bandwidth (Up/Down) [kbps/kbps]: 444 / 9,727
Data Transferred (Sent/Received) [MB/MB]: 11.72 / 51.68
Output Power (Up/Down) [dBm]: 12.5 / 18.0
Line Attenuation (Up/Down) [dB]: 17.5 / 29.5
SN Margin (Up/Down) [dB]: 26.5 / 12.0
Loss of Signal (Local/Remote): 262,143 / 0
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 262,146 / 0
FEC Errors (Up/Down): 0 / 52,051
CRC Errors (Up/Down): 0 / 14
HEC Errors (Up/Down): 0 / NA
Crazy thing is, at times my connection is super fast, around 8-9 MB, but it seems to drop over time (week by week). I've had a BT engineer check my wiring around 3-4 months back and all was fine. Any advice? Any chance this line training thing could be reset or something?
Thanks.
Re: Low speed at the moment?
03-02-2011 9:52 AM
Last month, yes my fault, I forgot to update my card details. I had a new card. When my payment was not taken, the next time I connected I was informed and corrected the problem and payment taken immediately. However, at that time as reported but I did not know it at the time, there was a problem with 'the supplier' in my area - Norfolk. This was evident amongst other things with accounts where payment failed and the speed profile would be wrong i.e. traffic management. So it would seem that the traffic management system is not robust enough, quick enough to slow you down, but not capable to restore the profile when all is restored.
I have no problem withy traffic management, but it is this that is in error this time. I ahve followed instructions but speed is still low, although improved.
03-02-2011 10:21 AM
Last speed test:
Today 10:17 716 kbps (89.5kB/s) 373 kbps (46.6kB/s) Share
Today 10:13 702 kbps (87.8kB/s) 373 kbps (46.6kB/s) Share
Today 10:03 1047 kbps (131kB/s) 375 kbps (46.9kB/s)
03-02-2011 11:42 AM
Today 11:39 6542 kbps (818kB/s) 378 kbps (47.3kB/s)
I'll keep an eye on things. Hope I can get a better speed, but I suppose that will do. Hey, I'm greedy
03-02-2011 1:59 PM
08-02-2011 9:58 AM
Best service I've had/tried so far is SKY's, believe it or not.
With BT/PlusNet I get incredible stats etc. but I never get that actual speed, if that makes sense. I've even had a BT engineer change/test cables at the exchange (whilst with BT BB) and local box, but it seems no matter what they do, I just cannot get the speed suggested by my stats. Again, not an expert, so excuse the lack of technical terms..
Also, this line training thing (DLM ?), it just seems to mess things up. My connection seems to become stable and then all of a sudden my stats change and my connection changes for the worse. Why does this have to be so hard.
Oh, can someone explain to me why my Maximum Bandwidth (Up/Down) [kbps/kbps] may say at times be 15,464 (or similar), but if I where to call support they'll tell me "your line can only support 5/7 meg" etc. which is what I get, most of the time. What the hell does that mean? When I signed up with PN I was given an estimate of around 13 mb. I have been connected at speeds higher than 6 mb and all SEEMED to be OK. Just weird.
But again, not an expert at all.
Is my SNR OK?
14-06-2011 10:53 AM
Maximum Bandwidth (Up/Down) [kbps/kbps]: 1,076 / 8,492
Bandwidth (Up/Down) [kbps/kbps]: 443 / 8,215
Data Transferred (Sent/Received) [MB/MB]: 2.36 / 21.65
Output Power (Up/Down) [dBm]: 12.0 / 20.5
Line Attenuation (Up/Down) [dB]: 18.0 / 30.5
SN Margin (Up/Down) [dB]: 22.0 / 16.5
FEC Errors (Up/Down): 0 / 0
CRC Errors (Up/Down): 32 / 1
HEC Errors (Up/Down): 7 / 0
Re: Is my SNR OK?
14-06-2011 11:01 AM
Did you have a lot of disconnections or line problems before
I assumed that the speed is actually 8215 and not 8125 and that you are on ADSL2+
The line may be banded but I am never sure about the actual banding levels
14-06-2011 11:05 AM
14-06-2011 11:11 AM
You have a number of disconnections which wont help matters. How is your kit set up? Are you using extension sockets/cables? Do you have a test socket you can plug into?
Jojo
14-06-2011 11:39 AM
Trying the test socket now (so cannot reply etc.). If you could test or whatever, that would be great. Thanks Jojo.
14-06-2011 12:27 PM
Thanks for your time. Now everything is set up the way it is I've ordered an SNR reset. I'll keep checking for the progress on that and keep you updated when I know more.
Jojo
14-06-2011 12:54 PM
No, thank you Jo. I'll keep the router switched on and will not reset, as advised. Great speaking with you, thanks again for all your help.
14-06-2011 1:41 PM
Just checked and it seems to have worked. Your profile is now 12000. I've now upped the profile from our end so you should see the difference within the next 15 minutes.
Jojo
