BT66 Junction box
- Re: BT66 Junction box
BT66 Junction box
09-02-2014 7:37 PM
Hi all!
After driving around my 'currently' building housing estate, I found that the houses just built a few months ago have a BT66 junction box outside beside the front door.
(example)
Mine is just a plastic cover with the main line entering the house and going to the master socket like here
The reason I would like a junction box as above is so then I can easily put in telephone extensions from the junction box to the kitchen, as my sky box needs a telephone line connected. It would be a pain to drag a cable from upstairs to the kitchen downstairs, whereas where the cable enters is just a few metres away from the kitchen.
Also what are my options? Can easily fit a BT66 or even an external NTE?
(example)Mine is just a plastic cover with the main line entering the house and going to the master socket like here
Ex Plusnet Fibre customer. Sky Ultrafast (G.Fast) Customer using a Sky Hub 4.2. If you wish to say thanks, please click the thumbs up
Message 1 of 5
(7,039 Views)
4 REPLIES 4
09-02-2014 7:58 PM
Ask your present supplier as it is all down to the company who provide the phone line
Message 2 of 5
(4,783 Views)
09-02-2014 8:07 PM
How?
likely BT will do anything
Message 3 of 5
(4,783 Views)
09-02-2014 8:08 PM
Posted on their community forums
https://community.bt.com/t5/BT-Infinity-Speed-Connection/BT66-Junction-box/td-p/1166516
Message 4 of 5
(4,783 Views)
09-02-2014 8:18 PM
Sounds almost like you're trying to create some sort of notoriously troublesome "star" wiring arrangement, with each socket independently wired to the incoming line, which is not good for DSL.
I seem to be stuck with an outside BT66 and star wiring. Each time the phone line has died, an openreach engineer re-does all the connections in the BT66 until they manage to get it working again. Apparently replacing this dreadful setup with a modern master socket is just not going to be done for a voice fault. And the most recent time it was fixed, the fix was disconnecting one of the sockets, so then I had to complain about the £129.99 charge for the ridiculously-named "engineer home improvement service", but I suppose that's the fun you get if you don't have a test socket.
Message 5 of 5
(4,783 Views)
