BT test
- BT test
BT test
22-05-2024 9:14 AM
Ran the BT spped test and it showed 25Mbps. Something is wrong if I get 2.5Mbps I am lucky.
Message 1 of 3
(951 Views)
2 REPLIES 2
Re: BT test
22-05-2024 11:50 AM
A little more detail may elicit some help. Why did you run the test, a screenshot of it would help, and what does your Help Desk (Hub1) or Technical Log (Hub2) report?
Message 2 of 3
(899 Views)
Re: BT test
22-05-2024 12:44 PM
Are you resting over a wired or WiFi connection?
Can you post a screen image of the following after hiding your details.
Message 3 of 3
(871 Views)
