BT test
bogart99
BT test
Ran the BT spped test and it showed 25Mbps. Something is wrong if I get 2.5Mbps I am lucky.
2 REPLIES 2
Fixes: 388
Re: BT test
A little more detail may elicit some help. Why did you run the test, a screenshot of it would help, and what does your Help Desk (Hub1) or Technical Log (Hub2) report?
Fixes: 118
Re: BT test
@bogart99
Are you resting over a wired or WiFi connection?
Can you post a screen image of the following after hiding your details.
