BT Wholesale Broadband Performance Test FTTC
- Re: BT Wholesale Broadband Performance Test FTTC
25-06-2014 11:52 AM
It will be lower speed - Not sure..
At the old place the estimate was 50mbps and you know what I got before and after DLM ruined it.
Here - not so sure although I am told all my line is copper (the last one was 100M Aluminium) so we will see.
Estimate here is 48-50 but as we know they are always conservative to under promise and over deliver which is never a bad thing
25-06-2014 11:56 AM
25-06-2014 11:58 AM
It's cheaper to get 2 or 3 FTTC lines and bond them - really it is.
25-06-2014 12:03 PM
25-06-2014 12:06 PM
Even if you do get it. Try buying it. I tried BT res and business. No one wanted to know.
Their loss. I still have my digital cities voucher too
25-06-2014 12:09 PM
As soon as I get screenshots, I'll forward them on.
25-06-2014 12:10 PM
25-06-2014 1:50 PM
Quote from: Chris Ideally, if you're able to do it from home, that'll be best as I believe the test also reports on the IP address that you were assigned at the time too.
There's no immediate rush if you can't do it until tonight for example.
No problem, I'll do it when I get home later.
Just as a side issue for them, I keep seeing HTTP500 errors when trying to send the results (have to close tab and open it again before it'll work) but that has happened on Safari, Chrome and IE, spread over 2 laptops. Sometimes it takes 2 or 3 goes before it'll actually send the results successfully.
25-06-2014 2:08 PM
I've just had an e-mail from BTO saying their system is sending out random and mis informed e-mails. So I would ignore that one totally.
25-06-2014 2:09 PM
25-06-2014 3:53 PM
25-06-2014 5:30 PM
Thanks for chasing it up
*EDIT*
It would appear I spoke too soon. I was able to retrieve it once, but have not been able to get the information since.
25-06-2014 9:49 PM
I think it's not related to one of the problems I'm chasing where the Speedtester doesn't work at all after 14 days, more that it intermittently works (on a rare occasion). The more information I can get, the better!
26-06-2014 3:31 PM
26-06-2014 3:52 PM
Out of interest, how long does it take BT to update your IP Profile after a sync?
Router resented this morning at 3.5Mbps higher, but IP Profile hasn't changed according to their tester.
dick:quote
